Rim dimensions?
I know this has been discussed before, But what rim dimensions fit our cars?
Dimensions?
Needs to be 114.3mm bolt pattern. That translates to 4.5 inch. 5 lug obviously. Factory wheel offset is 55mm. People have gone as low as 35mm, but depending on wheel width, that might cause the tire to rub the fender. Factory wheel width is 7.5 in, with 8 and 8.5 being accepted as plenty wide enough for anyone not producing power too much greater than stock. A few member have used 9in wide wheels. This required either fender work, or in one case an extremely hard suspension with almost zero travel. It is possible to fit up to a 19in rim without noticable fender rub. The dimensions I would shoot for when looking for a wheel would be 48-53mm offset, 8in wide, 18in diameter. 16 and 17 diameter if 18s create too harsh a ride for your taste. 7.5 wide if you are going to use this wheel in snow. -- To give you the most basic of answers for your question, (correct me if I am wrong here) any rim that matches the bolt pattern will "fit". EDIT: Any rim that matches the bolt pattern AND fits inside the wheel well will, well, fit.
"That which can be asserted without evidence can be dismissed without evidence." '92 Dark Teal SVX LS-L, >146,000m 3 pedals, 5 speeds., restoration underway. 2012 Honda Insight, slow but cute. Last edited by NikFu S.; 01-10-2007 at 10:37 PM. |
Thank you very much for this useful information.
[QUOTE=NikFu S.]Dimensions?
EDIT: The dimensions I would shoot for when looking for a wheel would be 48-53mm offset, 8in wide, 18in diameter. 16 and 17 diameter if 18s create too harsh a ride for your taste. 7.5 wide if you are going to use this wheel in snow. EDIT ================================================== What size tires would one recommend for the above scenarios.......I'm probably more interested in a 17 x 7.5 rim.........48 - 53 mm offset THANKS
HENRY 92 SVX Claret(No More) 12 Camaro ZL1 89 Yamaha FJ1200 07 Yamaha FJR1300 "GO RAVENS" |
I am really not the person to ask about tires. I know very little about what works. To date, I have not even had "real" tires on my car. Though that will change very soon.
Correct me if I am wrong....
But if I understand it right, the smaller the positive offset 35 vs stock 55 would move the wheel closer in to the suspension rather than move it out closer to the fender.
That's backwards. In that pic the SVx would be the wheel on the left. Imagine putting say, an old Camaro wheel on the SVX. It would poke out quite a bit because the center of the wheel is lined up almost symmetrically with the rest of the wheel, looking at it from the front along the rolling edge.
I get it now.....
I was not moving the bolt plate in respect to the wheel width. It actually would look like the wheel on the right would it not? (not exactly since that one shows negative offset but something like it)
Dave |
Interesting.. Basically any wheel that would work for an 05+ STi would fit the SVX
- 2005 WRX STi, Crystal Grey - 1992 SVX LSL Touring, Pearl Last edited by Gizmotronicus; 04-29-2007 at 11:23 PM. |
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 2014 Hyundai Avante Limited ... 203,000 miles. Actually quieter and smoother than the Outback 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . |
Good WebSite for this type of question!!
Good people sleep peacefully in their beds at night, only because rough men stand ready to do violence on their behalf. |
