Too many lights!!
My ABS light has been on since I bought the car. We checked everything out and there is no reason for it to be on. How can I get it to turn off? My E brake light came in this morning and will no turn off. The brake is not on and even when I put it on and off it will not turn the light off. Is there something to check under the car to make sure it isn't keeping the light on from the last time I put the E brake on.
Thanks
1992 SVX LS-L 77,000 Miles 1983 Alfa Romeo Gtv6 1990 Alfa Romeo Spider 1973 TVR 2500M |
The handbrake light is usually caused by this:
http://www.subaru-svx.net/forum/show...00&postcount=6 For the ABS light, read this: http://www.subaru-svx.net/photos/files/How-To/14364.jpg
Subaru ECU and TCU Website 1992 Alcyone SVX Version L 1992 Alcyone SVX Version L 1994 Alcyone SVX S40-II 2004 Subaru Legacy 2.5 SE Sports Tourer 1996 Subaru Legacy 2.2 GX Wagon 1988 Subaru Justy J12 SL-II |
First, remove the brake master cylinder cap under the hood to check the fluid level.
Then make sure the black diaphram in the cap is not "popped out", or extended beyond the upper cap recess. It should NOT look like this; It should look like this; As far as the ABS light do you know about the built in self checking system? It is cooler than Elvis on ice!
Do you have butter and bread? Is your toaster working? Me so hungry...
-SSSVX 92 LS-L TEAL since Aug '01 92 LS-L YELLOW since Mar '05 |
Are you signed up for Reading yet!?
Thanks alot for the input. I don't know anything about the built in check for ABS. The brake light turned off sometime during the day I figure. I got out of school and the light has not turned on since.
Check the How-To documents to find out about checking codes.
will do, thanks
Brian |
Life begins around 70 MPH and stops when you dont see the flashing blue lights anymore! Scott & Audrey's Subaru SVX's 1995 Green 1992 Black |
We thought about the bulbs...I mean it works but not the best idea. We will try and read them and if we have no luck we will go a different path. This weekend I think is stereo weekend and next weekend will be read light weekend.
