Old 03-05-2007, 05:57 PM
granca69 granca69 is offline
P/S PUMP, who has one
need a p/s pump, must be in good working order, in aus would be good, in melbourne better,
Old 03-05-2007, 07:23 PM
-JJ-'s Avatar
-JJ- -JJ- is offline
Endangered Species
Send a message via MSN to -JJ-
why not rebuild the one you have?
1992 Pearl / Black SVX
removed intake silencer, k&N pannel filter, trans cooler, 94 JDM 4eat, Noltec front swaybar mounts, Motorsport D&S disks with EBC Greenstuff pads
Old 03-08-2007, 07:58 AM
pylon500's Avatar
pylon500 pylon500 is offline
the Flying Member
Send a message via AIM to pylon500 Send a message via Yahoo to pylon500 Send a message via Skype™ to pylon500
If it went anything like the way mine went, there's not much left to rebuild!
The whole inside of the body was all chewed out, not to mention all the bits that used to be vanes, although they are replacable, but I don't think the housing is?.
I fitted one from a Liberty, but needed some specially machined bits to make it fit, I also no longer have the 'idle up' feature for parking, although this didn't work before anyway.
Another problem is if your P/S pump disintegrated, there will now be particles all through your system.
I flushed mine with about 4 litres of P/S fluid, then fitted a high presssure fuel filter on the return line to the pump.
Arthur.
'80 DL 4x4 Wagon-White (gone)
'91 DL 4x4 Wagon-White (gone)
'92 SVX LSi Burgundy/Black with wing. (gone)
'04 Liberty B Spec 3.0R wagon-Silver
'02 Outback 2.5 wagon-White For Sale
I Don't Drive Fast, I Just Fly Low!!
I've moved to Taree , check out my progress at Picasaweb.
That's a 'V' in SVX dammit!
