Fuel system diagram needed
anyone know where I can find one?
I looked through that, it's not in there...... onless I missed something.
Are you looking for the electrical or the plumbing?
I need plumbing, not wiring
in the engine bay??
Tom |
yeah pretty much. The tank is just feed and return right?
Hope this helps...
basically what I'm trying to figure out is why there are 3 fuel hoses coming out next to the intake manifold rather than just two. Are there 2 feed lines and one return, or 2 returns and 1 feed?
Fuel Supply -> engine (high pressure hose, screw clamp) Fuel Return -> tank (high pressure hose, screw clamp) Fuel Vapor -> cannister by ABS pump (fuel vapor hose, spring clamp)
Dave - 03 Baja - 92 SVX - 86 Brat - 08 OB 3.0 Last edited by Hocrest; 09-11-2007 at 10:36 PM. |
what would happen if I caped off the vapor line (engine is going in a 911)? any negative affects on driveability
your tank cannot vent and will prob cause vapor lock unless you are plugging the engine side only
Tom |
here's why I'm asking for a diagram. I'm building a custom fuel tank and the tank is going to have a vent, but the Porsche fuel system is obviously different than the Subaru system. I haven't decided if I'm going to be running any emissions controls so I'm not sure if I'm going to vent through a charcoal canister or just to the atmosphere. If I can pass a visual inspection without it, then I won't put it in. I just need to know how the Subaru system works so I can modify the fuel rails with AN fittings and fun the fuel lines in a way that will work with the engine controls.
