Tranny fluid
Ok, my awd transmission is slipping and the fluid is burnt. Its a 1992 with 97k on the first tranny. It slips from dead stop (otherwise its fine). If I change it know theres a 50% it might help it from slipping. But the other 50% it may just totally kill the transmission from working at all.
Orignally when I got the car, I was going to rebuilt it (when its no longer driveable). I made up my mind I want a 5 speed conversion (if I have to replace or rebuild it). What should I do? Also whats the best 5 speed transmission to use? I can't find any good threads.
1992 Subaru SVX LS-L #5045 Dark Teal 1992 Subaru Loyale Wagon Gray (SOLD) 1999 Subaru Impreza 2.5RS Coupe Black Ruby (SOLD) 1969 Subaru 360 Deluxe Ivory White 2005 Subaru Impreza WRX STi World Rally Blue 1993 Subaru Legacy L Wagon Teal Metallic (SOLD) 1998 Subaru Impreza 2.5RS Coupe Rally Blue Pearl [SIGPIC][/SIGPIC] |
I've read that if the fluid is burnt, the tranny is pretty much toast and if it's running, it just doesn't know that it's toast yet. With that said, the sites didn't recommend a fluid change because once changed it seemed to accelerate the failure.
Dustin
-Dustin 1992 Ebony LS-L w/191k miles Mods: a few and acouple more 1995 Brilliant Red L/AWD w/154k miles Mods: Stebro catback exhaust, K&N drop in filter, ECUtune ST1v5, 4.44, lots of JDM goodies 1992 Pearly LS-L w/154k miles Sold Mods: 4.11, rust 2008 DGM Legacy spec.B w/245k miles Mods: Cryotune Stage3, VF52, bushings galore, STi pink springs, Bilstein HDs My Locker The only man alive who drives three "Subu SVS's".......according to my insurance company Last edited by odepaj; 09-29-2007 at 06:27 PM. |
My high speed clutch in my tranny was burned out pretty bad, causing slipping between 2-3 and 3-4. Sounds like your slow speed clutch that is causing hte problem.
If you like auto trans, you can either get a rebuilt trans and throw it in with a trans cooler and hope for the best, or consider a 4.44 or 4.11 swap. They're pretty reliable and there's quite a few knowledgable folks around to assist or do it for you if you want. If you like manual trans, I'd go with a 2003+WRX transmission, such as is in mine. Personally, I'm a big fan of the 5speed in any car, and I love my SVX that much more now that it's a 5speed. It's a whole different car. If you want a 5speed swap, I recommend TomsSVX, the guy who did mine. It's very tight, smooth shifting, and feels 100% natural. I swapped the original shifter with a WRX short shifter for a shorter throw, then sawed 2" off the top, to make it shorter in height, and make the shifts closer together. I have about a 2.5" shift distance from first to second gear, it's a wrist flick shift that requires near zero effort.
*No SVX at the moment...* 1987 Winnebago Elandan 35' 2001 Yamaha Roadstar 1600 2004 Ford Excursion Eddie Bauer, 6.0litre Power Stroke Diesel - Daily Driver. Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways, scotch in one hand, body thoroughly used up, totally worn out and screaming HOOOOYA !!!!! |
[QUOTE=SubaruSVXCrazy;496624] "If I change it ..theres a 50% it ...... may just totally kill the transmission from working at all."
Are you saying you fear changing the transmission fluid because to do so may totally kill it? I don't think so. To simply drain and refill the transmission is a typical maintenance procedure and should do no harm. If you are suggesting doing a power flush and refill then you may be taking some risk. Getting the old, burnt fluid out of the transmission should be a positive thing to do. Does anybody disagree? Preston |
drain the fluid and drop the pan...you will probably find a bunch of rollers and metal in the pan.
I wouldn't continue driving the car. It's time for you do that transmission swap you've been dreaming of. |
[QUOTE=PDSides;496756]
burnt tranny fluid
i agree as well it saved me from replacing the transmission as quickly it took approx 9 months to die after changing the fluid. you dont want the fluid that is burnt and has tiny bits of metal in it to keep flowing / trying to flow and causing further damage. if it is shot, it's shot changing the fluid wont affect this
On a slightly different subject... I am planning on changing the fluid in my tranny, a '95 AWD. It is running fine and the fluid isn't burnt looking or anything and I was planning on using a flusher and putting in synthetic. Is this ill-advised??
Jesus is the remedy 2015 Expedition EL Ecoboost Ebony Pearl '95 Subaru SVX LSi Home of the Bontrager Works 22mm rear sway bar!! |
Thanks guys for all your help. I guess I'll change it due to the majority saying yes. I'll let you guys know what happens.
Another question, If I want a 03 wrx tranny would I need the drive shaft and the differencal (I'm assuming it the whole axel) too?
May I suggest Amsoil as a first choice.
92 SVX LS Pearl 94 SVX LSi Barcelona Red 82 Brat 4WD Bob |
Synthetic
synthetic is the only way to go ALL my vehicles get the good stuff either amsiol or mobile 1 normally mobile 1 as it can be bought locally
