Old 06-04-2002, 01:50 PM
Mr. Pockets's Avatar
Moderator
Removing rotors
I need to remove the rear rotors on my wife's Legacy tonight. They work, and they're true, but they're so damned nasty that I don't even want to put new $30 pads on them.
I know that there are two little holes on the face of the rotor. You're supposed to thread bolts into those holes to separate the rotor from the hub. But what size are the holes?
I should have measaured last night, but I didn't. And now I won't have time tonight to go home and then run to Lowe's.
Thanks.
2005 RX-8 Grand Touring
2005 Outback
2002 Mercedes-Benz E320 wagon
END OF LINE
Old 06-04-2002, 02:22 PM
Boone
Take a look at this thread.
http://www.subaru-svx.net/forum/show...&threadid=2876
Old 06-04-2002, 02:46 PM
Moderator
Thanks - I really should make better use of the search engine. My current rate for pre-searching is about half of my tech q&a posts.
2005 Outback
END OF LINE
Old 06-04-2002, 03:39 PM
wawazat??'s Avatar
Yeah, I'm still around
Hammer Time
Actually, I use a BFRM (big freakin rubber mallet) to knock mine free. I don't know the thread pitch on my BFRM though.
Down to none
Old 06-04-2002, 04:27 PM
Aredubjay's Avatar
Rat Fink Member ~:o)
Boone, you are a wicked, wicked man.
Randy Johnson
Mike Davis -- at Reading VI
Old 06-04-2002, 05:21 PM
Beav's Avatar
Beav Beav is offline
Not as old as Randy
Bolts? We don't need no stinkin' bolts! I just smash the bejesus outta them with my 48oz. wedge-head hammer. Haven't lost one yet. Then again, I've got a little experience too...
Old 06-04-2002, 06:14 PM
immortal_suby's Avatar
Thread Killah
I had my front rotors turned at a pep boys once on my suby wagon. I walked into the shop through the overhead door to find the tech heating the rotors with a torch and then beating the bejeezuz out of them with a bfh in an effort to remove them.
Sir... step away from the vehicle, put the hammer down slowly. You need to remove the large center hub nut bfore that rotor will move at all.
None of my vehicles have seen the inside of a pep boys garage since.
I could have killed that guy on the spot and I think my case would have held up in court with a jury of my peers.
Locker Link
2015 BRZ Limited 6MT
Old 06-04-2002, 06:24 PM
Beav's Avatar
Not as old as Randy
heheheh....yeah, but that's an entirely different critter than an SVX. You should have made him place his fingers between the hammer and the rotor, just as a lifetime long reminder.
Old 06-04-2002, 10:25 PM
deadeye95
I just did this on my SVX two weeks ago...
Assuming your other Suby uses the same size...
At Pep Boys, get the M7x1.0 20mm coarse thread. Comes in a little green pack of 2.
I got a M6 and an M8 just to save another trip. But the M7 was the charm.
Old 06-04-2002, 10:27 PM
deadeye95
Coarse thread cap screw, that is.
Old 06-05-2002, 12:32 AM
Aredubjay's Avatar
Unless, of course, someone who pees his pants when people start beating on his car with a hammer, is looking over your shoulder.
Randy Johnson
Old 06-05-2002, 09:43 AM
Moderator
I was actually able to remove both rotors without a hammer or bolt of any kind.
I sprayed a little WD40, as Beav suggested, on the lugs and the rotors pulled right off.
I suspect that I may need to replace the right-rear caliper on the car, but we'll see.
2005 Outback
END OF LINE
Old 06-05-2002, 11:24 AM
kuoh kuoh is offline
Replace the caliper, why? You see signs of mechanical damage?
KuoH
Old 06-05-2002, 11:54 AM
Moderator
KuoH
It's sticky. I've cleaned and greased the slides as well as I can, but I think the piston is sticking.
The car is measurably better now with the new rotors and pads in the rear, but the right rear is still noisy after stopping sometimes...
2005 Outback
END OF LINE
Old 06-05-2002, 12:50 PM
Ok, how are you deducing that the piston is sticking? Unless you drain the fluid out, you can't really move it around like the calipers on the slides.
KuoH
