Won't start, not in park, can't move shifter
Hi everybody,
I have a weird problem. Here's what happened: Haven't driven the car (1992) much lately as it's been replaced as my daily driver. When I did get it out, the shift lever was very stiff. Very stiff... had to really work it to move from park to drive etc. Drove it up beside the house and charged the battery and now it won't turn over. Windows and everything else works fine, I'm confident that the battery has enough juice. The park light on the dash isn't lit up, neither is the reverse light or any other gear lights. The shifter looks like it's in park. I can't push the button on the shifter in to move it, it's locked. Turning key, no crank. I'm stumped. Can't even get it into neutral to push it out of the way. Car's stuck, I'm stuck. Any ideas? Thanks Alan |
I don't know about the starting problem but I had a simular problem where I couldn't get the shifter back into park. The button was broken. It would not push in. There are 2 little screws on the shifter that you can loosen or take out and you can pull the shifter up and off. Then you will see a white button on top that you should be able to push down on and be able to shift. That is what was wrong with mine. The plastic button on the shifter was broken. I drove it around like that till I got a hold of another shifter. Not sure if that is your problem so just a thought.
Paul 1969 Corvette 1995 SVX L Safety Option Package, HID's & Awsome Braking (Svxfilies/TomsSVX), JDM Clear Corners, JDM Boxer Engine cover, Transmission Cooler, AND NOW JDM FOLDING MIRRORS! 1995 Corolla 2003 Highlander |
At the top end of the shift slot, near the P position, is a little oval button. This is an emergency release for the gear lever mechanism.
Subaru ECU and TCU Website 1992 Alcyone SVX Version L 1992 Alcyone SVX Version L 1994 Alcyone SVX S40-II 2004 Subaru Legacy 2.5 SE Sports Tourer 1996 Subaru Legacy 2.2 GX Wagon 1988 Subaru Justy J12 SL-II |
Not all cars had this button. Mine didn't until I had this problem and had YT change out the shifter
Thanks for the replies. |
If you push it down you should be able to move the shifter without having to step on the brake.
Excellent! This allowed me to get to neutral and fire the beast up. It won't properly engage park, so I'll have to take it in and get that checked out. At least now I can get it there! Thanks for the help Alan |
Glad I can help. I have been helped so many times by the people on this network. I'm glad I can return the favor. Good luck with the car.
