when did Subaru make changes to SVX
What improvements did Subaru make to the SVX after 1992? I remember reading on the forum that some initial flaws (something to do with transmission?) were corrected in later years, was wondering if these came after my 94?
they added an external filter which did help lower temps a little bit and increased the system capacity which therfor means the fluid breaks down at a slower rate. The same modification was available for the earlier models based on a recall i believe. It is generally a first step in owning an SVX to make sure there is an external filter, change it with the fluid regularly and add an external cooler while you're at it if the previous owner has not. They also offered a front wheel drive version in 94.
-Mike ECUTune2v7 - 4.11 5 Speed - Sprung 6 Puck Clutch - D&S Rotors - SS Brake & Clutch Lines - HKS Panel Filter - HeaderBack Exhaust -80GB Hard Drive - GroupN Engine Mounts - - some other "tricks"
[SIGPIC][/SIGPIC] In progess: track down mystery noise <-identified, paint the new dash, get better pic Spring plans: Replace Trans - Integrate ECU with the carputer - Suspension - Go back to STI Filter - Paint? Maybe not - Next Oil change: Purolator L30165 Member #995 | My Locker | My New Locker Catch you next at: ? Auto-X ? Last edited by Speedklix; 04-12-2008 at 12:43 PM. |
thanks, I thought maybe the modification was added pre-94, I have no idea if I have external filter, will have to find out . you can tell I know next to nothing about cars... Slowly learning. With my SVX I wish I knew a lot more.
My '96 doesn't have the external filter. It does however have a cooler.
[SIGPIC]http://www.subaru-svx.net/forum/image.php?type=sigpic&userid=5569&dateline=1207440 507[/SIGPIC] Naught but by the grace of God "42" Current Stable By Age:'89 Subaru XT6 Silver "Audrey" as in Hepburn '96 SVX LSi #767Brilliant Red "Lil Red" Now on the front burner. Looking for a totalled, but running parts car. |
They also removed the filtration material from the transmission cooler in the radiator. It would get clogged and prevent the transmission from cooling properly.
Simply switching from conventional tranny fluid to synthetic fluid is a large step in the right direction.
I have yet to put a cooler on mine, but one of the first things I did when I got the car was flush the transmission and replace the fluid with Amsoil synthetic automatic transmission fluid (ATF). I guess it's hard to tell damage form the outside, but so far so good. MY old fluid didn't look as bad as I thought it would, but getting the old gunk out and putting in fresh oil is always a good thing. That said, I DO have a cooler in the garage waiting to be installed. I didn't really see the point of installing a cooler in the middle of the winter though.
Jesus is the remedy 2015 Expedition EL Ecoboost Ebony Pearl '95 Subaru SVX LSi Home of the Bontrager Works 22mm rear sway bar!! |
more than just a filter
Subaru revamped the flow in the transmissions to the high clutch. Extra passages were opened up to allow more flow from the high clutch to allow it to operate at a cooler temperature and also keep more fluid flowing rather than allowing the hot fluid there to get even warmer.
Subaru also changed to manual belts in the front and added a passenger air bag to the dash. Tom |
Tom, do you know when did they make the changes to the transmissions?
the changes were supposed to be made starting in 94 but I have never seen anything conclusive along the lines of when they actually took place in the model year. All I can say for sure is that the factory reman transmissions that were used to replace the failed ones MUST have been of the new design with the modified case and oil pump gasket.
Tom |
This is the Subaru Technical Service Bulletin dated March, 1994, outlining the changes/modifications to the 4EAT transmission to improve reliability.
http://members.tripod.com/quick_svx/.../42749013.html .
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 2014 Hyundai Avante Limited ... 203,000 miles. Actually quieter and smoother than the Outback 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . |
