Old 04-27-2008, 10:47 AM
ykobayashi's Avatar
ykobayashi ykobayashi is offline
Send a message via AIM to ykobayashi
Difficult Start, Rough Idle then its fine...
Hey All,
Been a while since I have posted. I just broke the seal this week on the SVX and brought it out of its winter hibernation. The car is a 1995 SVX L AWD with about 56k original miles.
Been since last year that I have had this issue. The car turns over but I have to crank it 5-8 times or more in some cases, to get it to start up. Each time it sounds a little more willing to start and catches and idles for a few seconds but then stalls. I keep cranking and it then eventually starts up and then idles but the idle is rough. If I keep it idling for a couple minutes or so the car then starts to smoothen out and within 3-4 minutes it's a completely smooth idle.
In some cases I will throw a CEL but it will go away once the idle smooths out. I noticed that the engine cooling fan stays on until the idle smooths out. I don't know if that is normal or if its a side effect of the rough idle. Once the idle smooths out the car performs without a hitch.
Last year before putting the car away I ran it with a couple tanks of Chevron Techron Fuel System Cleaner. It seems to have helped the idle smooth out sooner but I don't know if that is just coincidence. Spark plugs have been changed. They were changed out after this issue came up. I don't know what the deal is. If anyone has any feedback it would be great!
Thanks,
Yoshi
Yoshi
[B]1995 SVX L AWD - Original Owner
65k - Brilliant Red
Mods: K&N Drop In Filter, Sony aftermarket CD/MP3 Stereo and Speakers, Sumitomo HTR+ Tires
2004 Mazda 6S 5-door - Steel Grey - 5 speed manual transmission - Daily Driver
2011 Mazda CX-9 - Wife's ride
Old 04-27-2008, 11:15 AM
Manarius's Avatar
Manarius Manarius is offline
Might be something that is Coolant Temperature Sensor related.
-Jason
-Obi Wan Kenobi
Old 04-27-2008, 02:21 PM
kwren's Avatar
kwren kwren is offline
When you try to start it...
Does the engine seem to turn over fast like normal?
Old 04-27-2008, 07:20 PM
LetItSnow's Avatar
Still Cant' Say the Z-Word
+1. Get that code to make the diagnosis easier?
Old 04-27-2008, 08:17 PM
poweredx2 poweredx2 is offline
Did your issue start before your k&n filter,my car would stall at lights and my idle was very rough with the drop in filter,switched to a conical no issues,or your o2 sensors could be going.
Old 04-28-2008, 09:39 AM
Schralper's Avatar
Schralper Schralper is offline
I've had/have similar issues. But no CEL.
I think it might be the air diverter under the manifold.
I've found if I turn on ignition but not start, wait 10sec and then start it seems fine.
I have a K&N drop in but the issue was there before the air filter.
I'm gonna clean MAF and replace O2 sensors in a couple weeks.
I'm also gonna send the injectors out for cleaning before to long.
WFO!
http://www.cardomain.com/id/Schralper
"You all laugh cuz I'm different
I laught cuz you're all the same."
Old 04-28-2008, 10:49 AM
kwren's Avatar
when trying to start,
does the engine turn over fast... like normal but no start?????
Old 04-28-2008, 02:13 PM
Octanerush Octanerush is offline
sounds like water temp sensor. but could also be crank/cam position sensors
check the cel. the code would be stored on there even if light doens't stay on
Old 04-29-2008, 11:46 PM
ykobayashi's Avatar
Issue started after the K&N filter but I have had the filter in for the last several years and this issue cropped up late last summer. I dunno, might be the K&N filter's oil on the MAF?
I'll pull it and see what the MAF looks like. I doubt it though, if it was the MAF then why does the problem seem to resolve itself once the car warms up?
I thought about the O2 sensors but I thought when they "go" all that happens is I get poor gas mileage? I am I wrong?
Thanks!
Yoshi
Yoshi
65k - Brilliant Red
Old 04-29-2008, 11:52 PM
ykobayashi's Avatar
The car cranks like normal it just won't start. The battery is fully charged and has been on a trickle/float charger all winter. It takes about 5-8 (or more) tries to get it to start.
Yoshi
65k - Brilliant Red
Old 04-29-2008, 11:56 PM
ykobayashi's Avatar
I'll try that 10 second trick and see if it works! Is there a post on how to clean the MAF sensor? I did it once on my old 94 Ford Probe, but I can't remember exactly how I did it. I remember I used some kind of aerosol spray and a rag. I am running my original O2 sensors, but again, would something like a faulty O2 sensor cause this kind of issue? I understand that what would happen is all I would see is dismal mpg. Please enlighten me if I am incorrect.
Thanks,
Yoshi
Yoshi
65k - Brilliant Red
Old 04-30-2008, 12:13 AM
kwren's Avatar
Sorry,
no idea.....
Old 04-30-2008, 06:39 AM
LetItSnow's Avatar
Still waiting on the code... Lil' help?
