Used Tires on Rims ?
I have read that it is bad to buy mix matched tires for the SVX, but what about buying used rims on used tires assuming the tires are all the same and reletively evenly worn?
Re: Used Tires on Rims ?
I don't see why not! People buy used rim/tire combo's all the time! If you notice a difference, like one is bald and the rest are 7/10 then yeah it's a problem. Otherwise, not really.. Just make sure they are the right size for your vehicle or you'll end up with problems...
1992 Pearl White LS-L "Ruslana" #4946 - 180k on body, 95k on engine. Mods: ECU bead crush, 15 min mod, 20 min mod, drilled/slotted rotors & Axxis ceramic brakes, SS lines, 17" Evoke F1 wheels, XS-HF137 Sony Xplod speakers, 6000k HID's (lows & fogs), resistor mod, 1½" Sleek Spoiler mod, custom exhaust by svxfiles, '02 WRX aluminum racing radiator by svxfiles, Summit Racing 400# x 300# springs w/ Koni's by svxfiles, ClassGlass fiberglass hood /w scoop, Nevin's rear sway bar, '97 grille, phenolic spacers, custom LED interior lighting, custom paint. †"War doesn't determine who is right, only who is left"† Work to be done: Tinted windows, clear/LED tail lights, tailbar mod, "Power Mode" mod, Supertone horns, clear corners & headlight lenses, 2 pc splitters or custom bumper, Alcyone side skirts, TruSpeed Stage III SVX Intake, Hydra, 4.44 tranny swap, JDM auto folding side mirrors, engine rebuild, super charger, STi seats, bone leather interior /w SVX emblem, dash overhaul, SVX decals, paint (stock color). Total cost?: 22k At least it's going down..
Just make sure they are ALL the same tire size, and ALL the same tread depth. If they are, you should be fine.
On subaruoutback.org they suggest that all tires be within 1/4 inch of each other in diameter. I measured my mixed snows with a soft measuring tape wrapped around the middle and all were under a 1/4" different.
if they are directional, make sure that is correct!
keith |
