Old 12-29-2008, 08:13 AM
gwomack's Avatar
gwomack gwomack is offline
Water in trunk
I have noticed water in my trunk in the well with the spare tire. Also noticed condensation in the tail lights. Anyone have this problem and hopefully a solution? Is there a seal around the trunk lid that could be causing this? No moisture that I can tell inside car. Thanks.
Never mind. found it in forum
Old 12-29-2008, 08:42 AM
knight'sSVX knight'sSVX is offline
Re: Water in trunk
I've read in the previous threads that they're common with our SVX's. Mine does the same thing, condensation in the tailights seems to dissapear when weather changes. You could keep one of the 2 rubber drain plugs off, or open for water to drain in the spare tire area.
92 LS liquid silver ---> pics here:http://s36.photobucket.com/albums/e8...VX%20LS%20AWD/
Old 12-29-2008, 11:49 AM
SVX JAZZ's Avatar
SVX JAZZ SVX JAZZ is offline
Tired
Re: Water in trunk
Mine does this as well. I seem to remember a post a long time ago mentioning a drain from the sunroof gets clogged and causes this. I may be way off...
Many years ago I drilled small holes in the bottom of my tail lights to "vent" the moisture. It has worked well.
Old 12-29-2008, 12:04 PM
Freeman's Avatar
Freeman Freeman is offline
Unregistered User
Re: Water in trunk
Drain from the sunroof gets clogged and causes flooding in the cab of the vehicle.. Not in the trunk..
As for the drilling, you think there is anything less extreem that can be done? Like adding silicone or additional seals?
Mods: ECU bead crush, 15 min mod, 20 min mod, drilled/slotted rotors & Axxis ceramic brakes, SS lines, 17" Evoke F1 wheels, XS-HF137 Sony Xplod speakers, 6000k HID's (lows & fogs), resistor mod, 1˝" Sleek Spoiler mod, custom exhaust by svxfiles, '02 WRX aluminum racing radiator by svxfiles, Summit Racing 400# x 300# springs w/ Koni's by svxfiles, ClassGlass fiberglass hood /w scoop, Nevin's rear sway bar, '97 grille, phenolic spacers, custom LED interior lighting, custom paint.
Old 12-29-2008, 12:29 PM
SVX JAZZ's Avatar
Tired
Thumbs up Re: Water in trunk
Ah... I knew it caused flooding somewhere... The holes I drilled were in the bottoms of the light housing. It can't be seen outside the car. I took the light housing out and used a very small drill bit. Gosh I did this like 10 years ago. Immediate fix.
Old 12-29-2008, 12:50 PM
bwb3's Avatar
bwb3 bwb3 is offline
Cruisin' in Gator Country
Re: Water in trunk
I took the driver's side trunk side panel off and found the drain hose for the radio antenna disconnected. Also found an empty bottle of vodka.
Gene
Gene and Ben
Old 12-29-2008, 09:28 PM
redlightningsvx's Avatar
Collision Refinishing Tech
Re: Water in trunk
I had this happen and didn't notice after a month. Mine wasn't clogged but was pointing in towards the floor pan. My guess was that when I R&I my doors I must haved bumped one of them to the cabin.
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
Old 12-29-2008, 10:38 PM
kwren's Avatar
kwren kwren is offline
Re: Water in trunk
Gene
An open container...
Get rid of it immediately!
Old 12-29-2008, 10:42 PM
kwren's Avatar
Re: Water in trunk
A shop vac works well to get the water out and pretty takes care of the remaining moisture in the spare tire area.
Keith
Old 12-30-2008, 02:20 AM
Re: Water in trunk
It can be the gaskets between the tail lights and the metal. It will leak through that area as well.
Old 12-30-2008, 07:24 AM
Mensaf's Avatar
Mensaf Mensaf is offline
What do you mean wrong SVX?
Re: Water in trunk
Sure it isn't your tail light gaskets? I got mine from Liberty Subaru for about $50. Problem solved.
Old 12-30-2008, 10:49 AM
Re: Water in trunk
Mensaf - look at the post above yours.
