Sealing exhaust donuts??
I got all 3 donuts, bolts and springs to fix a leaking cat, but can not get them to seal. Cleaned the sealing surfaces and all, but no luck--completely that is. Is there some trick to getting these to mate and seal??? Thanx kevin
Re: Sealing exhaust donuts??
Are all 3 joints leaking?....just one??? If the doughnuts are fresh and the spring-bolts are installed correctly the hardware works surprisingly well. Not to be a smart-a$$, but after similar experience with mine I have to ask; "are you sure that the leak is where you think it is?" My leak turned out to be a crack hidden under a heat-shield just inches away from where I was 100% certain it was.
Glenn
"The only thing necessary for the triumph of evil is for good men to do nothing" Aaron Burke 1993 25th Anniversary Edition #63 of 301. R.I.P. Rojo 7/24/2008 She saved my life! 1997 Ebony Mica Pearl LSI. BLACKBERRY 1998 5-Spd Legacy GT Wagon in Glacier White: NUBURU 2005 Cadillac STS in Sandstorm Metallic: STORMY Veteran and farthest traveler of 1st SoCal2MuseumsMeet2010. http://www.subaru-svx.net/photos/user.php?RojoRocket |
I had all 3 of mine replaced, a flange welded on, and new hardware at cole muffler for $79
1992 Liquid Silver/Black LSL LeveL10 Stage 3 Trans and associated stuff |
May be some other leaks--put in donuts to fix leak and when rechecked you can see where exhaust gases are blowing by. Almost seem out of round, flanges that is, and new donuts do not seal well--thought there might be some trick to help them seat.
