Replacing rear struts
Ok, for a while now i've noticed that my tires are REALLY close to my wheel well and have burned holes into the wheel well. Then I looked at my FSM for height specs for the front and rear struts and here are the results I got. Fronts were around + or- 5 from the stock 380mm from the center of the hub and the Rears were off -30mm from the stock height of 335mm. So i'd say my rear struts are severly shot and need replacing. I'm going to just go with OEM since I can get the whole strut assembly for -$100 a side. My question is that are the removale of the rear stut assembles pretty much unbolt the brake hoes, remove the stut housing bolts, then remove the 3 bolts on the top of the strut underneath the rear shelf? It just seems too easy and I just wandered if theirs any special tools i'll need besides a torque wrench and any special ways to do this, also will I need to get it aligned after this. Thanks
Seth 94' Barcelona Red w/ Tricoat black 2-tone AWD Ls -Sold Mods:AWD conversion/4.44 swap by Budfreak, Custom red interior lights, Custom Satin black dash, Power mode switch, Cold air intake, Permecool tranny filter,Sony xplode 10" sub, Sony xplode 1000w amp, Blitz in-line driver, DDM Tuning 6000k HID's, New paint job/body work by me, 97' Grill, QC shift kit, 17'' MB Motoring rims, 15&20 min mod, front & rear urethane swaybar bushings, Custom fiberglass sub box, Custom red led a/c control unit, perrin lightweight crank pulley, Black wrinkle finish powdercoated intake manifold w/ clear hoses , 02' outback heated/power black leather seats Soon to come:Fiberglass hood, upholster ALL suede to black leather Past subies: 92' Pearl White/black top LS-L-SOLD 96' Legacy Outback-TOTALED 99' Legacy Outback Limited 30th anniversary edition-TOTALED 98' Forester L -Totaled Other toys: 99' Forester S -WRX brake upgrade, soon an 04 wrx motor swap 06' B9 Tribeca-Stock 1982' Yamaha xj650 Maxim Mods: work in progress Last edited by redlightningsvx; 04-25-2009 at 05:55 PM. |
Re: Replacing rear struts
100 dollars per side is quite a decent price.
However I went the stock route a long time ago and they failed within a year. I would check out your mounts as well just to make sure that they're not rotted out.
Tim 92 Liquid Silver SVX 5MT 2009 BMW Z4 (Gone) 2012 Camry V6 SE |
The problem with buying stock struts is that they have sat on a shelf for 17 years and the seals have dried out.
It may be that your rear springs are sagging. They are cheaper to replace than struts. Are the struts leaking? Does the back end bounce repeatedly when you go over a bump? |
search the forum for a possible how to on this..also other threads contain a list of all of the required tools, spring compressor, 19mm wrenches, sockets, rust penetrant. Get the upper strut mounts and the rubber isolaters as they rust and deteriorate.
My car was 2 inches low in the rear because of these.... and get an alignment.
Eric Rebuilt P/S pump info... http://www.subaru-svx.net/forum/showthread.php?t=50918 If your car wont start info... http://www.subaru-svx.net/forum/show...ighlight=click |
Strut assemblies usually doesn't include the springs. You need the compressor to remove your old springs from the dead struts and install them on the new ones.
If you're getting the assembly including the spring for $100.00 per side, that's a sweet deal indeed. |
You will be complaining when you need to do it 3 times in the next year and the SOA will say sorry your warraty is up when the 365 days passes from the initial purchase and you're left with very nice, shiney $100 Koni shells. Oh wait that was mine! Best part is it was less than 4k on 'em. Then again, I'm sure you'll have better luck
British vehicles are my last ditch attempt to keep the nasty Italian thoughts in my mind at bay. So far its working. |
The struts themselves have no effect on ride height. Zero, none. They only affect the handling / ride characteristics, and how the car absorbs bumps.
The things that would cause a rear end sag would be bad mounts or springs, or possibly damaged spring perches on the strut bodies themselves (although I've never seen this). A car can have completely shot struts, but will still maintain proper ride height if the springs and mounts are in order. It's my understanding that our mounts tend to rust out, so I'd check the mounts first. If those are OK, look at your springs.
Ebony/Gray '92 LS-L, @123k - bought 01/17/2010, parked for 10 years. Getting back on the road. |
I'm going to take a look at them tomorrow. So what the best way to inspect them, removing the rear shelf?
It'd probably be the most time consuming, but most thorough to make sure the rubber spring seats are still intact as well as the condition of the mounts.
Well taking out the interior for me is a piece of cake. I'ved had pretty much all of it out 3 times. I'll post what I find tomorrow. Thanks
Ok, just spent about 5 min tearing out the interior and looked at the top of the strut mounts and the rubber looks brand new. I also stuffed my hand into the wheel well and felt across the entire top of the strut and didn't feel any corrosion or holes. So my only guess would be both springs are shot?
Well looking at the whole thing over again the foam that goes over the top mounts were torn like someone removed them before and the rubber looks brand new. I'm wondering if both struts were replaced before except the springs which could have twice as many miles as the struts.
It was both rusted struts mounts that made the rear sagging.
94 Bordeaux Pearl SVX Lsi B&M cooler with Aux ATF filter. QC Kit Plus 06 Sti Gold Wheels. SOLD 92 Claret WRX 5 speed ECUTune 1AV1 Gold STI Wheels & more. SOLD 92 Teal SVX LSL lowered with Konig. SOLD 92 Black SVX LSL with B&M cooler & Aux filter. Small Car Shift Kit. Gone 94 Red SVX L FWDwith LSL Leather Interior. SOLD 92 Teal SVX LSL....with B&M cooler & Aux filter. Small Car Shift Kit. SOLD 95 Polo Green........With Trany Problem. GONE Almost complete Rear Wheel Bearings Job with Pictures in my locker My Locker http://www.subaru-svx.net/photos/user.php?pearlm30 |
I finally got my rear springs today and removed the old ones out. With the struts out the right rear I pressed down and it came back up so that was good but, when I got to the right rear I pressed the strut down and it wouldn't come up so I just ordered a new one and the foam helper as it was destroyed in the blown strut. Good news is the car sits A LOT higher like it should. My tires were literally touching the wheel well now it sits about 2-2.5 in above
