Old 05-02-2009, 07:43 AM
SVX_MY_BABY's Avatar
Fender Liner
I've been getting a rubbing sound from the drivers front on hard cornering. Upon inspection I've discovered that the inner liner has a pucker in it. There is a molded bump toward the top front that fits over a metal seam. This is where the liner has puckered and it is bulged by a couple of inches. You can see where the tire is rubbing it and beginning to wear through it.
I tried pushing it up but it just pops back. Is there a trick to re positioning the liner? My worry is that crud, salt etc. will get behind it and rust out the area.
Old 05-02-2009, 10:38 AM
redlightningsvx's Avatar
Collision Refinishing Tech
Re: Fender Liner
The liner is supposed to go behind the rubber moulding around the fender lip.
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
Old 05-02-2009, 01:30 PM
Re: Fender Liner
It is behind the molding. It's the side closest to the engine that has this V shaped bulge similar to a folded tent card. It runs about 5 inches.
Old 05-02-2009, 03:31 PM
kwren's Avatar
kwren kwren is offline
Re: Fender Liner
I would remove the thing and see exactly what the story is.
Applying a heat gun should allow you to get it shaped back good enough and hold in that position till it cools it should stay there.
Just a thought...
Keith
