Old 10-04-2009, 11:16 PM
92sVx1987 92sVx1987 is offline
a couple of Q's
how the freak do i get to the the sparkplugs and if i need a speacial tool were do i get it.
also does anyone kno were i can get parts for the car at decent price lol including a wiring harness for the stereo?
ps i kno my grammer/spelling is terreble lol no need to tell me or well have fun poking at it lolz
Old 10-04-2009, 11:28 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Re: a couple of Q's
The plugs arent that bad at all, see the how-to section above for the procedure. A few extensions, a swivel/u-joint, and patience are helpful.
Try subarugenuineparts.com, 1stsubaruparts.com, subaruparts.com, or rockauto.com to name a few.
BTW Go Avalanche!
Old 10-04-2009, 11:40 PM
Re: a couple of Q's
heck yea Avs ALL THE WAY lol anyone here from colorado
Old 10-05-2009, 12:16 AM
Re: a couple of Q's
As far as the wiring harness, use the search and you will find a member here that sells them.
Old 10-05-2009, 12:22 AM
Re: a couple of Q's
jeez got enough svxstasy lol man u live in a good area to most of the parts ive found are up there in beautiful washington along with smallcars who seell the 5spd i want
Old 10-06-2009, 07:12 PM
dennyo dennyo is offline
Re: a couple of Q's
keep your fingers crossed that the boots come off with the coil.
Old 10-07-2009, 11:08 PM
Hondasucks's Avatar
Subaru Technician
Re: a couple of Q's
Radio harness - PM SVXDc he makes them, he also has a good writeup on how to get your stereo out without screwing up the dash.
Spark plugs - Get NGK platinum or Denso Iridium plugs, the Iridium ones are spendy but they are good for 90,000 miles, instead of the 60,000 the platinum ones are good for. Don't get any other type of plug, stay away from the Bosch Platinum plugs, etc, they aren't worth it. Autolite, champion, etc.. are crap. (Trust me)
As for DOING the plugs, you will need a 12mm for the bolts that retain the coils, a 1/4" drive ratchet and shallow 12mm socket are what I use. As for the plugs themselves, the skinnier the ratchet you can get, the better. If you can find a 1/4" drive air ratchet that will fit in there, with one of those really skinny 1/4" to 3/8" adaptors, that would be ideal, however the only one I've run into that fits is $300+ from Snap-On, however their fine-tooth hand ratchet works great for getting the plugs out. I've also had good luck with those little thumb ratchets (basically a knurled wheel with a socket drive in the center), break the plug free with a regular ratchet, and then use the thumb ratchet to get the plugs out.
When putting the plugs back in, I like to put some spray silicone on the threads, this helps them thread in easier as well as helps them come out easier next time. (Anti seize works, however it is conductive so you must be careful not to get any on the tip of the plug, as then it will not fire.) After the plugs are in, spray silicone in the rubber tip of the coil also helps with installation, and helps keep the boot from sticking to the plug next time. The clear spark plug boot grease they sell at parts stores works well here too.
The back plugs are a bit of a chore to get to sometimes, however you can undo the two nuts on the underside of the car that hold the motor mounts to the subframe, and then using a floor jack with a block of wood under the oil pan, raise the engine up a few inches. You won't get it totally clear, but it does help, and if you unbolt the dogbone you can swing the engine to one side for more clearance. (This also makes replacing the cam cover gaskets easier, however if you choose to replace them, the spark plugs are VERY easy to get to once the cam cover is off)
1986 VW Jetta
Old 10-08-2009, 12:35 AM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Re: a couple of Q's
Yeah +1 on not using autolite or champion..... anything besides NGK on an import is asking for it. I never had to jack up my engine though, the supposively hardest plug (drivers rear) actually was quite painless..... the main thing is gently easing the new plug all the way back to the hole without picking up the gunk inside the recess on the plug tip or threads. Getting the coil and plug out was pretty simple..... just be GENTLE..... no yankie the coiley.
