Feeler: full turbo kit, bolt on, everything you need!
Well my head gasket finally went after 240k on my svx so I am going to start my build for 750awhp. With that being said I have to change out my full set up so I am putting mine for sale. Here's what it comes with:
Garrett 60-1 turbocharger (4" inlet, .63 hot side) Halix 38mm wastegate Tial 50mm blow off valve Bolt on turbo up pipe 3" down pipe with wastgate recirc (bung welded for wideband) Custom built charge piping Custom front mount intercooler Bumper beam built to fit front mount intercooler Stainless steel feed/ return lines with Russel fittings extra feed line Forge boost controller all silicone couplers (high quality) T-clamps Oil pan with bung welded on for return line T-block for feed line 92 obdI svx ecu with ecutune stage 2v7 chip Z32 MAF sensor with pigtail Nissan 370cc injectors with pigtails Walbro 255lph fuel pump Boost gauge This is everything that you need to boost your svx. I had this on mine and it worked amazing. I will include full color install manual with purchase to make it even easier for people that have never done this kind of thing before. Seriously offers only, lowballers will be ignored.
1992 SVX: JDM STI short geared 6-speed swap, COBB short shifter, slotted cross drilled rotors, Smallcar Clear headlight lenses, 1997 Grill. 1992 RHD WRX: EJ20G, 16G, Cusco Coilovers, Wilwood 4pot/2pot brakes, Defi Genome 60mm gauges, Exotic speed downpipe, 3.5" A'PEXi spec GT catback Last edited by the_paynter; 10-20-2009 at 10:53 AM. |
Re: Feeler: full turbo kit, bolt on, everything you need!
Thanks. -Bill
I dont know why the photos came out so small lol, ill try to get more tomorrow
(note these pictures are when the kit was first finished and the last picture the turbo is just bolted on. These pictures are to just show how well everything fits)
1992 SVX: JDM STI short geared 6-speed swap, COBB short shifter, slotted cross drilled rotors, Smallcar Clear headlight lenses, 1997 Grill. 1992 RHD WRX: EJ20G, 16G, Cusco Coilovers, Wilwood 4pot/2pot brakes, Defi Genome 60mm gauges, Exotic speed downpipe, 3.5" A'PEXi spec GT catback |
I would totally take your injectors and 2v7 chip if Bill decides he wants everything else. If you are interested, let me know! Thank you.
-nevin
Jesus is the remedy 2015 Expedition EL Ecoboost Ebony Pearl '95 Subaru SVX LSi Home of the Bontrager Works 22mm rear sway bar!! |
Please post an asking price. Interested.
2009 Volvo C70 T5 2008 Volvo S80 V8 2006 Range Rover Sport 2001 Audi S8 |
Just curious what the status is on this!
how much too?
