headlight washers
Hello, i just had a problem on my SVX, the headlight washers are not working, water is not eject, how is it a problem ?
![]() Last edited by Pierre-Olivier; 11-01-2009 at 02:15 PM. |
Re: headlight washers
It could be: No water in the tank A blown fuse Burnt out motor in pump Loose or broken connection to the pump. Blocked nozzles. If the pump is not pumping when you press the button then you need to check if you have an electrical problem, and I'd start with the fuse. Joe
