Old 11-08-2009, 10:58 PM
cruisen_15's Avatar
just thought id share this
3 weeks ago my legacy stopped running and i torn it down and heres my crank:
Old 11-09-2009, 03:20 AM
scoobymal's Avatar
scoobymal scoobymal is offline
Re: just thought id share this
No oil? Over revved?
Old 11-09-2009, 07:51 AM
ShiuludeSVX's Avatar
It's scary just to think you could snap something like that in a realatively small engine.
But, given the tourque that the smallies can put out on the inside......
It's still a wonder though
The Worm
_______________
June '91 Claret LSL #1733, Enkei RS-5's x 16", Original Paint, accompanied by Beautifully speckeled Front Bumper, Sony Audio Components, Small Car Shift Kit, "How to" Hood Lifts {Perfect}, "15 Minute Suspension Mod"
Motorsport Floor Mats. Perma-Cool External T. Filter, New Front Axels {1/2008}. "Classic Radiators" unit "$36 coil alternative" and Tranny rebuild at 287k 8/2012
'05 Infinity G35 Coupe.
No Mods, 33K Miles
Old 11-09-2009, 09:30 AM
I assume that was after you beat the hell out of it?
Old 11-09-2009, 10:01 AM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
lock one end and continue to apply torque.....
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 11-09-2009, 10:55 AM
cruisen_15's Avatar
not over revved. perfect oil. just happened ot of no where. only 10k miles on rebuilt motor
Old 11-09-2009, 11:52 AM
Did you rebuild?
I expect the Mains must have locked up if it was oiled and not beaten.
The Worm
_______________
No Mods, 33K Miles
Old 11-09-2009, 01:12 PM
cruisen_15's Avatar
well before the rebuild the crank had seen some high temps and eventually i spun a bearing so me and a buddy rebuilt it but we took the crank to a machine shop and once i picked it up they said it was bent so they balanced and straightend it... so im guessing between the wear before the rebuild and having it worked on at the shop this is probably why it broke
Old 11-09-2009, 01:47 PM
Bshade's Avatar
Bshade Bshade is offline
Send a message via AIM to Bshade
That’s the new style two piece crank JDM twight! Makes much more power when the two half ca work independently from each other. Oh wait is that the other way around? Less power when not working together. Well good luck with the rebuild, again.
Brad the Superlative!
1988 Firebird Trans AM, 1987 BMW 325is,
1978 Dodge RamCharger, 1989 Chrysler Conquest,(2)
1988 Merkur XR4TI 1973 Super beetle Baja Bug
2006 Chrysler 300C SRT8 1996 Buell S1 Lightning
1998 Subaru Forester 1993 Chevy K2500
Old 11-09-2009, 06:51 PM
Elliott's Avatar
Elliott Elliott is offline
I wouldn't ever reuse a crank from a motor with a spun main bearing unless there was no other choice. A spun rod bearing is usually fine, but when a main bearing goes it puts all kinds of weird stresses on the crank. I've heard it described as a "jump rope" effect by some builders.
Old 11-10-2009, 05:38 AM
There's your bug. Try bending a fork over and over again.
Apply heat to it. Now imagine that fork on a grand scale.
The Molecular structure changes every time, no matter what you do to recover the shape. It's gonna break.
Sorry to hear that it turned out that way, but the machine shop can only do so much without having someone refabricate a new item.
The Worm
_______________
No Mods, 33K Miles
Old 11-10-2009, 11:22 AM
MiataMania's Avatar
MiataMania MiataMania is offline
42 Autosports
Send a message via AIM to MiataMania
Man.
Nice. weight savings ftw.
1990 Mazda Miata - Undergoing CSP Race Prep
1995 Subaru SVX 5MT - DD
