Can you adjust caster and camber on a stock SVX?
Can you adjust caster and camber on a stock SVX without doing any modifications? I have my car in the shop as I type this to have the front end aligned, and they are telling me that there is no adjustment on the 1996 SVX for anything other than toe !?!?!?!?!
HELP! |
Re: Can you adjust caster and camber on a stock SVX?
Exsqueeze me.... what and where is the "top wheel knuckle bolt"? Sorry, but I don't have a clue. Thanks for the reply! |
The bolt above the top of the rotor
http://img193.imageshack.us/img193/7955/july09059.jpg
"The things you own end up owning you. It's only after you lose everything that you're free to do anything." 92 Pearl White Ls-l (138k) Euro Headlights & Blinkers, 97 Grill, Euro Tail Lights, SS Brake Lines, Stebro Exhaust, Slotted Rotors, Classic Registration 96 Legacy Outback (206k) 5-speed 2.2 Lightweight Crank Pulley, Group N Trans & Motor Mounts SOLD Wanted: Steering Wheel |
That is the typical spot for most vehicles with this type of suspension set up if the shop you have it at doesn't know this I would strongly suggest going to a different shop. I would be even more worried if you were trying to get the 4 wheel alignment done!
Front - one bolt on both side is eccentric, thus providing camber adjustment. Caster is via the upper strut bolts. Toe is via tie rods.
Rear - no camber or caster in in stock config. Toe is adjusted with the lateral links. You might consider going to another alignment shop ![]() -Bill
Worst part of it all........ it's being done at the Acura dealership where I work
![]() I just gave them the info that you all provided me, and they are going to redo the alignment. One question though..... on the caster, is it adjustable without drilling or modifying the upper strut bolt holes? |
1991 SVX L JDM |
True! This said, you can open them up a little to get some additional caster (yes, Racer X does have this mod
![]() -Bill
