manual front wheel dive tranny?
Does anyone know if Subaru ever made a Front Wheel Drive Manual Transmission? And if so what is the name of it and where could I possibly buy one??
Thanks ![]() ![]() |
Re: manual front wheel dive tranny?
hi in the USA subaru made 2and 4 wheel drive cars till 1996 model year when they decided to just sell AWD in the states ,if your looking for a trans to use
i dont know how well a lecacy 2wd one would hold up to the power of the svx ,fitting it against the engine isnt a problem good luck |
Though wondering why anyone would want to have just fwd as well.
Unless you happen to have a fwd only svx and don't want to add the rear diff? |
It's a little more involved than just adding a diff, but it is possible.
That thing would spin LOTS of right front tire.
10 more HP, and WAY cooler!
![]() but I NEED AWD! ![]()
Good lord why........
1994 SVX L - FWD Barcelona Red 190K miles ~ SOLD 1994 SVX LS - 5spd AWD Emerald Green 202k miles PWR Radiator, HID 5000k, New paint job with issues, 17" STI BBS wheels, converted to 5spd AWD from FWD. Purchased from SVXyGirl 2/20/09 -- Undergoing complete rebuild 1993 Justy 4wd 5door- Teal of sorts , beater. 2008 OBXT Newport Pearl 65k miles |
You'd want an early Legacy FWD 5-Speed, as the early Impreza's FWD 5-Speed had a different spline for the axles, so they won't work with the SVX axles, the Legacy one should work with the SVX axles
Huck Subaru Ambassador 92 SVX LS-Tour Magnaflow Exhaust, 5-Spd-AWD ![]() 88 XT6 AWD 5-Speed "Bride of FrankenWedge" 15 Impreza Premium Sedan 15 Crosstrek XV 5-Speed My 5-Speed "How-To" Write-up 1976 Pontiac Firebird Formula Current Count of Subaru's Owned.... "70" |
Ditto but in 94 1/2 the imp went with the same spline count in the fwder as the lego. You could if needed to make your own axles but it would be a pain. A fwder SVX 5 speed wouldn't be my first choice but every fwd Subie I've driven has been a better car then the awd version of the same model.
British vehicles are my last ditch attempt to keep the nasty Italian thoughts in my mind at bay. So far its working. |
Lee
SVXx2 92 SVX LS-L Silver 92 SVX LS-L Burgundy (structurally challenged with 2792 miles) 96 SVX LSi Red 92 SVX LS Pearl (Parts) 01 F150 4X4 Red (+6 with other members of the family) FREEDOM IS NOT FREE |
Loyale and XT boxes will not fit.
You need a Legacy or Impreza one. M |
Unless you install a 1.8 or 2.7! ![]()
why do you think this?
94 Emerald LS w/ awd 4.44 swap 199xxx daily driver Stage 2 ECUTune chip, 370cc injectors, ECUTune valve body and TCU, solid rubber motor mounts from a forester, outlaw phenolic spacers, COBBTuning lightweight blue crank pulley, Bontragerworks 22mm rear sway bar & endlinks, StrongFlex poly front sway bar bushings, Powergrid adjustable front sway bar endlinks, 17" MOMO CORSE RPM wheels w/ Toyo Proxes4 225/45, drilled/slotted rotors f/r, stainless lines, ceramic pads, Blue silicone radiator hoses, power mode switch, gold jdm hood badge, 20% tint all around, Hella optilux xtreme yellow fog bulbs parts waiting to go on car: the rest of the strongflex polyurethane suspension bushing set |
My guess is that Ben will say.
Less weight (true, about 90#s) Less parasitic losses.(true) Quicker accelleration.(if you have no wheelspin) Better gas mileage(who cares) More fun to tail out. The parking brake is now a steering tool.
