Old 08-16-2002, 07:26 AM
Ticallion
Where is the silencer?
Hey guys. The silencer in the intake.. where is it located? Is it before the afm or after the afm? What does it look like? anyone have a pic of what i should look for? A K&N was installed before i bought the car, so he might have already removed it.
Old 08-16-2002, 07:41 AM
Green1995SVX
It is located in the fenderwell under the airbox. You have to take the wheel off, and pull back the wheel well lining to get to it. Good luck!
-Mike
Old 08-16-2002, 10:22 AM
Ticallion
Good god. Alrighty thanks!
Old 08-16-2002, 10:06 PM
dromano's Avatar
dromano dromano is offline
You will have to tug a bit to get it out. I could not believe the size of the resonator. The sound is worth all the effort.
LS-L 92 black top silver bullet-Turned into a 2005 Jeep TJ Unlimited
2012 Outback 3.6R Limited!
Old 08-22-2002, 08:16 PM
Ticallion
GOOD GOD!! you weren't friggin kidding!!! That beast was HUGGEEE!! I had to remove the side marker to gain access to two nuts that were holding it from the front, as well as one nut that was right beside the airbox under the hood. When it came out, i couldnt believe my eyes. It was huge. I can fit a dead body into the freed up space. Nice place for an intercooler too ... seriously speaking, i took the hose with the slit and cut it in half at the slit. Is this a good idea? or should i just take that extension hose out altogether?
-Ross
PS: Once again, thanks for your help guys!!
Old 08-22-2002, 08:19 PM
immortal_suby's Avatar
Thread Killah
Leave the extension hose there, otherwise you will suck in some hot engine compartment air.
Locker Link
2015 BRZ Limited 6MT
Old 08-22-2002, 08:40 PM
casper150
i was just wondering, what do you gain by taking that thing out?
Old 08-22-2002, 08:49 PM
Ticallion
Mostly sound. It sounds alot cooler. I'm sure a few ponies are gained... but don't quote me.
Old 08-22-2002, 08:51 PM
casper150
oh,maybe ill rip mine out this weekend! just as soon as i figure out how to replace that damn glove compartment light bulb!
Old 08-22-2002, 08:52 PM
dromano's Avatar
A bit better air flow..the sound man, the sound..
reminds me of a 4bbl AFB with the pedal to the metal
Old 08-22-2002, 08:53 PM
Ticallion
LOL it's definitely worth it. A tip: take off your airbox under your hood, as well as the nut that's right in front of it on the fender. Also take off the front side marker to gain access to the two nuts that hold it. That should release it.
Have fun!
-Ross
Old 08-22-2002, 08:54 PM
casper150
i have the k &n drop in, it dosent afect that at all?
Old 08-22-2002, 08:55 PM
Ticallion
Only makes it better. I have the K&N drop in also.
Old 08-23-2002, 05:11 AM
I_Alcyone_I
I removed the all the plastic tubing and the seal that was around the plastic tubing, there is about 5mm of space between the air box and the hole in the fender, I will eventually seal it off from the engine compartment, but from how my car responds I'm not drawing in much hot air from the engine compartment since the path of least resistance is through the hole in the fender well. I definatly notice a difference in 50-80mph time, maybe a little in 0-60 but it definatly sounds way cooler now.
