clutch pedal stays down
so far my clutch pedal doesng come back up, do i need to bleed the lines more?
Tranny goes in, tranny comes out, tranny goes in.....AW ****, tranny comes out.... |
Re: clutch pedal stays down
You installed the tension spring right? Its usually not the line pressure that returns the pedal, its a spring, but if its going to the floor with little resistance then it needs to be bled more.
that big spring on the pedal? ya its always been on, if your talking about the spring for the clutch fork than no but thats pulling the fork in another direction anyways,
i've been bleeding it for like 4hrs with no change.
u gotta bleed it from the slave cylinder too. open the bleeder nipple and push in on the slave.
Eric Rebuilt P/S pump info... http://www.subaru-svx.net/forum/showthread.php?t=50918 If your car wont start info... http://www.subaru-svx.net/forum/show...ighlight=click |
The clutch master cylinder does not have a pressure retaining valve in it like the brake. So it is probably pulling air through the cups. Try just opening the slave bleeder, and let gravity bleed it out.
turns out i didnt hook it up to the pedal while under pressure.
