help before i break it
can someone tell me approx. where to put the jack stands after jacking the front of the car up? also where is a good jack point. i want to take the resonator out of the fender and i need to get the wheel off to do so. any help would be appreciated.
ps. i searched the archive with no luck
1992 Pearlie ... ??????k Sold 8/04 Kenwood KDC-MPV619 Wedgie Cupholder ![]() 1998 Acura Integra LS 74k Sold 1/07 2007 Toyota Tacoma Prerunner SR5 .04k! 2011 Toyota Tacoma Double Cab, 4x4 TRD Sport |
If you are using that whimpy thing they gave you, there are marking under the car. Look underneath. Also in the manual.
If you want a lift, there are beams under the car that the beams can go. You can easily tell where they are. If you hear any crunching sound, you are too late. ![]() Lwin
Lwin M. Maung (Member # 147) Current SVX: • NONE Previous SVXes: •1994 LE Barcelona Red 107k • 1992 LS-L Pearl White 143k • 1994 LSi Bordeaux Pearl 220k • 1992 LS-L Ebony Pearl 184k • 1992 LS-L Liquid Silver 145k • 1992 LS-L Liquid Silver 102k • 1992 LS-L Ebony Pearl 123k Other current cars:•2001 Jeep Grand Cherokee Black If at first you don't succeed, CHEAT!
well i was gonna jack up one side, put in a jack stand, then jack up the other side, and put the other jack stand in, then take the wheel off...i'll be using a hydraulic floor jack type thing, you pump w/ your hand and it goes up you know...so where do i put the stands? is there a slot or something
if yyou're only working that one corner, put the jack at the same place you would for the flat-tire jack. Then put a jackstand under the frame part where it attaches the lower A-arm. Let the jack down slowly so you know the stand isn't going on vacation anytime soon with you under there, then pull the wheel.
I put mine up with a floor jack where the body bolts onto the frame, right behind the front wheel, under the door. I didnt have any problems that way.
I started carrying a floor jack after I broke the crappy spare tire jack. |
i used that bolt also when i got a flat, but how do i get the jack there, and then move it away to put the stand under
Sorry, I dont know. I left the floor jack there while I did the work.
According to the FSM, the safety stands should be put where the trunk jack would normally go when jacking the car, that is, along the "edge", instead of on the frame.
They also suggest jacking it at the crossmember in the front, and on the diff in the rear, but my floor jack won't reach in that deep, so I usually jack on the frame, and put the stands at the "edge" of the car. I can scan the FSM if it'll help anyone. VK |
that would be really helpful, please do if you dont mind
Et Voila!
http://www.subaru-svx.net/photos/user.php?vkykam|4206 It's a mulit-page TIF file, so if your browser can't open it, download it and use the Imaging utility that comes with Windows to open it up (assuming you're a PC guy, of course). ![]() VK |
do you by chance have a similar picture file like the one you scanned but for jack points for the front end of the car?
It's all there. It's a 2 page TIF, so if you only see one page, you'll have to use another program.
Included is the front jack point (crossmember), rear jack point (diff), and jack stands/hoist positions. VK |
i cant figure out how to get the 2nd page up
I've separated it into 2 TIF's. Check my locker.
VK |
thanks a lot bud
