Where Can I get A New Alternator Plug ?
Would appreciate any help as to where I can find a new alternator plug ? The wires in mine have become brittle and are showing, causing all the lights to flicker. Thanks
Re: Where Can I get A New Alternator Plug
I think John "svxcess" found a source for these? If he doesn't reply here send him a PM.
Dave - 03 Baja - 92 SVX - 86 Brat - 08 OB 3.0 Last edited by svxcess; 12-05-2018 at 08:05 AM. |
Soldering iron, solder, and some new wire would probably save you the hassle of having to buy a new plug.
-Jason (8/23/07-Present) 1995 Subaru SVX LSi (197k) Polo Green (#1102) 03/95 Mods: DDM Tuning 4500k 35w Low Beam HID, 100w H3 Bulbs, Extra Ground Cables, 15 minute $12.96 mod, svxfiles designed transmission mount (), sporting a "new" tail light bar, silver BBS rims, custom power steering cooler (one that doesn't dump ATF constantly), new negative lead cable, no more third or fourth gear (1977-Present) 1977 Chevrolet Corvette (81k) Silver (12/01/2011-Present) 2005 Subaru Outback 2.5i Limited 5MT (97k) I have a bad feeling about this. -Obi Wan Kenobi Last edited by svxcess; 12-05-2018 at 08:04 AM. |
Re: Whan Can I get A New Alternator Plug
Find a place that rebuilds alternators, they usually have spares lying around.
That's how I got one. |
These are the plastic plugs on the passenger side of the alternator, for the voltage regulator, right?
Mine is intact, but pretty well baked brittle, and the wiring insulation is similarly brittle and splitting. I am having to charge the battery with an external charger every 2-3 days or so. (new battery last month...) I am thinking it might be approaching the time to get a re-built up-rated alternator, and do the wiring upgrade mod. a new voltage regulator plug would probably go along with that. Do the plugs come with a wiring pigtail to splice into the existing wiring, or does the plug require wiring to be pinned and installed into the plug?
"What you plan, and what actually happens ain't exactly ever been similar..." ------------ 1992 Claret SVX. Rescued from certain destruction, and still on the road, where it belongs. Waiting for a bit of a makeover, when I can afford it. 2005 Garnet Red Pearl Legacy GT Limited 5-speed. - The late great Subaru sport touring sedan. 1999 Classic Red Miata, Preferred equipment package 5-speed. Fun, fun, fun, in the Sun, sun, sun. Last edited by svxcess; 12-05-2018 at 08:08 AM. |
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 2014 Hyundai Avante Limited ... 203,000 miles. Actually quieter and smoother than the Outback 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . Last edited by svxcess; 12-05-2018 at 08:58 AM. |
Just wanted to bump this thread to thank John “svxcess” for all the helpful information on this topic. The alternator went out, as well as a tire going flat, so the SVX has been waiting for me to assemble some money to fix it. Now the money is assembled, so I am assembling parts. A new Maniac alternator, a Littelfuse holder and fuse, and a regulator plug replacement are all on order, and tires will be soon, too, to get back on the road properly, and reliably. The information thread on the electrical repair/upgrade procedure has been invaluable, thanks again.
"What you plan, and what actually happens ain't exactly ever been similar..." ------------ 1992 Claret SVX. Rescued from certain destruction, and still on the road, where it belongs. Waiting for a bit of a makeover, when I can afford it. 2005 Garnet Red Pearl Legacy GT Limited 5-speed. - The late great Subaru sport touring sedan. 1999 Classic Red Miata, Preferred equipment package 5-speed. Fun, fun, fun, in the Sun, sun, sun. Last edited by svxcess; 12-05-2018 at 09:21 AM. |
Re: Where Can I get A New Alternator Plug?
Call Christian at Maniac Electric Motors in Dallas, TX. 214-202-3250 Mon-Fri 9:00AM-3:00PM CST https://www.maniacelectricmotors.com/spalplhap.html Also available on Amazon.com for only $9.98 and free shipping. https://www.amazon.com/S-P-ALTERNATO.../dp/B00AY1ZU0A
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 2014 Hyundai Avante Limited ... 203,000 miles. Actually quieter and smoother than the Outback 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . Last edited by svxcess; 12-05-2018 at 09:23 AM. |
