Power steering cooler: Is it really necessary?
Random question, but I've been browsing NASIOC and came across a thread pertaining to P/S coolers. Obviously if you're taking to the track it makes sense (my classmate boils fluid in his 240 on track days), but is it really something that's a necessity on a street driven car? I've got the "clean up the engine bay" bug in my head and would like to do something about those ugly lines.
Those who've tracked their cars (lapping as opposed to Auto-X, since I assume continuous lapping would build heat to a much greater extent), have you run into issues with the P/S boiling over? Searching yielded no results on the subject.
Re: Power steering cooler: Is it really necessary?
I don't know how the pump would react to the new found pressure because of the lack of power steering cooler. I can tell you though that I'm pretty sure the stock one is about as useless as a part can get.
-Jason (8/23/07-Present) 1995 Subaru SVX LSi (197k) Polo Green (#1102) 03/95 Mods: DDM Tuning 4500k 35w Low Beam HID, 100w H3 Bulbs, Extra Ground Cables, 15 minute $12.96 mod, svxfiles designed transmission mount (), sporting a "new" tail light bar, silver BBS rims, custom power steering cooler (one that doesn't dump ATF constantly), new negative lead cable, no more third or fourth gear (1977-Present) 1977 Chevrolet Corvette (81k) Silver (12/01/2011-Present) 2005 Subaru Outback 2.5i Limited 5MT (97k) I have a bad feeling about this. -Obi Wan Kenobi |
That's my thought as well. If I ever came to a point that I thought the system needed cooling I would plumb in a small oil cooler. That silly tube is hardly an effective heat exchanger.
