Old 06-14-2011, 06:36 PM
The Molinator
AT Inhibitor Switch.. ???
Does the Inhibitor Switch on the AT only connect:
(1) Lights in dash for shift positions (P, R, D 3, 2, 1)
(2) Connect starter circuit in N and P only.. .
OR .. any other functions (connections)... .. . ???
Thanks..
Jim
