Old 10-28-2011, 11:23 AM
HELP can't get key out
My car was converted to a 5 speed. I turned off the ignition switch and now it will not got to lock so i can't get the key out. what controls the tranny to tell it it is park. My car acts like the auto Tranny is in Driver or N. Got to be a lever someplace that has moved . Where is it ?
Old 10-28-2011, 12:15 PM
AFBeefcake's Avatar
Subaru Swapper
Re: HELP can't get key out
Check the white 4 pin connector to the left of the shifter, under the shifter trim. There should be a connector plugged into it with two of the wires connected together.
Also try tuning the steering wheel a little. Some times if the wheel is in just the right spot you cant get the key out.
2005 Legacy GT
My WRX's Cardomain Page
Old 10-28-2011, 12:52 PM
SVX92-97's Avatar
SVX92-97 SVX92-97 is offline
John, did your car come with a converted owners manual
1995 POLO LSI 76K MILES SOLD
Old 10-28-2011, 01:01 PM
No but I have something better.
OK I see the plug , it is empty . 4 wires BRN/ W---Solid black Blu/w and a nother solid black . I drove the car 30 miles like this so i don't thoink it is the wheel
Old 10-28-2011, 01:12 PM
Old Fogey
Looks like pins 3 & 4, Blue/White and Black, complete the circuit. That's the Park position switch.
FSM 6-3 page 24.
Glenn
Old 10-28-2011, 02:01 PM
I just tried to jump it and still nothing . I wish I had the old plug. Must have fallen out .
Old 10-28-2011, 02:13 PM
SVX92-97's Avatar
Ah, the life of an automatic
Old 10-28-2011, 02:16 PM
The instructions said connect the 2 end wires . the wires are in order left to right Brown with black , then a black , then the Blue with white stripe , and finally a black . One set is the Park lock the other is the key lock . There is nothing in the plug now. how much draw is there in the ac position.
Old 10-28-2011, 02:57 PM
None if you disconnect the neg terminal on the Battery.
There is also a manual key release tab on the steering column. Under the column there are some holes, inside one of them is a small brass colored tab. Push that up or to the side and you should be able to get your key out.
It is not very obvious, you may need to lay down and look up for the first time untill you learn where it is.
Old 10-28-2011, 03:32 PM
I don't have that little button .
Old 10-28-2011, 03:40 PM
I just ran out to look at mine.
It is down at the base, right next to the lever to adjust the height. Not the height release on the side, but the height adjustment on the bottom center.
The metal tab is in a white plastic block, you can sort of see the spring holding it, you need to slide the tab towards the height adjustment button.
Once pressed, you still need to push the key in to turn it back.
Old 10-28-2011, 03:46 PM
Fixed !!!! P Not answered on this forum
