Thread Tools | Rate Thread | Display Modes |
FOR SALE: Remanufactured OEM Front Axle from a FWD SVX Subaru SVX
This is a genuine Subaru axle pulled from a 1995 FWD SVX, rebuilt with Subaru parts to Subaru specifications. This is NOT a cheap aftermarket replacement axle. This is as close to a brand new genuine Subaru SVX axle as you can get.
Based on feedback from members of this forum, it's clear that the FWD axle will fit on an AWD car. Be aware that the FWD axles and the AWD axles look different if compared side-by-side. Personally, I would use the same axle on both sides of the car to keep things balanced and avoid possible driveline issues. Subaruparts.com, which is the Tacoma Subaru dealer's online store has a new Subaru FWD axle for sale for this price; 28321 $341.84 Drive shaft assembly-front I'm asking $150 for this axle rebuilt with Subaru parts to Subaru specifications, plus shipping. That's a 56% savings on a new factory part. I'm giving SVX forum members a chance to buy this first. If no one buys it in a week or so it goes on eBay. You can PM me here if you're interested. Regards, Jim Last edited by svxcentric; 08-10-2012 at 08:20 PM. Reason: Member Feedback |
Re: FOR SALE: Remanufactured OEM Front Axle for FWD ONLY Subaru SVX
Yeah going to go ahead and disagree about the non interchangeable. IIRC the FWD axles that were on my car were swapped over to the 5spd. And if I remember the 4EAT were the same, minus the rear end (and a capped drive shaft).
1994 SVX L - FWD Barcelona Red 190K miles ~ SOLD 1994 SVX LS - 5spd AWD Emerald Green 202k miles PWR Radiator, HID 5000k, New paint job with issues, 17" STI BBS wheels, converted to 5spd AWD from FWD. Purchased from SVXyGirl 2/20/09 -- Undergoing complete rebuild 1993 Justy 4wd 5door- Teal of sorts , beater. 2008 OBXT Newport Pearl 65k miles |
You are correct sir. You can use the FWD axles in an AWD SVX. Might not be as good of an idea to use the AWD front axles in a FWD SVX though, since AFAIK the FWD axles are stronger. But they will still fit.
And I just remembered, when i went to get new axles for the front, I got the FWD because they were cheaper (core charge less). Back and Front are not interchangeable though.
Yea not even remotely close.
+1 for FWD front axles fitting on an AWD. I put some FWD from a '94 LS 2WD on my '95 LSi AWD a few years back. They ARE beefier, but a perfect fit!
