Old 08-10-2012, 09:58 AM
LastSVXintheChi's Avatar
LastSVXintheChi LastSVXintheChi is offline
Send a message via AIM to LastSVXintheChi
need help ASAP :(
so my GF drove my car to work today and said that just before she got there the steering got really heavy and the "battery" light came on the "stop" light came on and the "check engine" light also i think....she said it didnt make any other noise besides the normal lifter tick.
any ideas? because i have no way of getting there to help im at work and without a car.
thanks
Jared
1992 dark teal SVX LS
Old 08-10-2012, 10:46 AM
Green1995SVX's Avatar
Re: need help ASAP :(
thanks
Your steering/alternator belt probably broke or became very loose.
2009 Volvo C70 T5
2008 Volvo S80 V8
2006 Range Rover Sport
2001 Audi S8
Old 08-10-2012, 10:50 AM
if that isn't it....is it possible that my alternator has gone out again?
Jared
Old 08-10-2012, 11:15 AM
Probably not. This would not affect the power steering. As mike said, the belt likely snapped or somehow got loose. A new belt, and a 12mm wrench and hopefully she has some helpful coworkers?
Old 08-10-2012, 11:20 AM
ok good im hoping it just came loose because when i replaced the oil pressure sensor i had to take that belt off and i wasn't sure how tight to make it cus i didnt want to whammy it on....i have the wrench in the trunk so i just have to get there now or hope someone there can do it
Jared
Old 08-10-2012, 11:24 AM
do you know what size belt it is?
oh and thanks for the help guys
Jared
Old 08-10-2012, 12:37 PM
Most autoparts stores will be able to find the correct belt in their lookup.
I've never had one incorrect for an SVX. Other Subarus however, a whole different story.
Old 08-10-2012, 12:59 PM
If it's not the belt it's your crank pulley.
Old 08-10-2012, 01:06 PM
Nate that sounds a$$ backwards lol
hocrest uh oh that sounds like bad news for me
cross fingers belt belt belt
Jared
Old 08-10-2012, 01:33 PM
kwren's Avatar
kwren kwren is offline
Why not raise the hood and simply look at the belts
Keith
Old 08-10-2012, 01:38 PM
I am at the edge of my seat....... What was the outcome??
Old 08-10-2012, 01:56 PM
any ideas? because i have no way of getting there to help im at work and without a car.thanks
Keith
Old 08-10-2012, 02:40 PM
kwren's Avatar
If you can call her you should be able to walk her through it to at least take a look...
Might get a clue at least about the belt situation.
... worth a try?
Keith
Old 08-10-2012, 03:30 PM
just got back with the car...good news and bad news....
good news it was a belt, well 2 actually the alt belt came off completely and the a/c belt was about to break itself....so i took the ac belt off cus i dont have ac yet anyway....
bad news the guys at advance auto gave me the wrong belt (so nate you can put that one in the books lol) i guess tech the computer gave me the wrong belt cus all he did was read it off the screen and go get it....so the old belt is still on there.....
ALSO the crank pulley is very loose to the point where it hits the block a little bit...now can i just tighten it or does it need to be replaced?
Jared
Old 08-10-2012, 03:46 PM
dragoontwo dragoontwo is offline
Tighten it if you can to get it home. Once there, take it off and inspect it.
'92 SVX LS Pearl White - 6mt
