View Poll Results: Stripes for my 94 Emerald Green SVX | |||
No stripes | 16 | 72.73% | |
Single black centered stripe | 0 | 0% | |
Black centered stripe with very narrow black stripes each side | 2 | 9.09% | |
Option 2 in yellow | 0 | 0% | |
Option 3 in yellow | 0 | 0% | |
Option 2 in gold | 1 | 4.55% | |
Option 3 in gold | 3 | 13.64% | |
Voters: 22. You may not vote on this poll |
Thread Tools | Display Modes |
Poll: Should I get a stripe and what color?
Some of you may remember my 94 SVX with Young Tom's 246 whp engine build and the Whiteline rear adjustable links along with many other goodies. I'm finally going to have a nice respray by Dave Heinricks. I'm keeping it emerald pearl but was thinking I should have a stripe or two. By the way, I'm changing to a '97 grille. Here are my options:
1. No stripe 2. Single central black stripe 3. Wide central black stripe with very narrow stripes each side. 4. Option 2 in yellow 5. Option 3 in yellow 6. Option 2 in gold 7. Option 3 in gold What do you think?
____________________________________________ 95 LS-i Red, 31,xxx; bone stock for now; Daily Driver 94 LS-i Emerald Pearl, 106,xxx,; 246 whp; Tomyx snorkus and HKS Cold air intake; PWR aluminum radiator, silicone hoses; Inline thermostat; enhanced coolant routing; external power steering and oil coolers; Phenolic intake manifold spacers; 2004 WRX 5 speed transmission; ACT Clutch Kit, Heavy Duty Pressure Plate, Lightweight flywheel, performance disc; Group N motor mounts; ‘07 WRX 4-pot front calipers, cryo-treated slotted Tribeca rotors; Hawk HPS ferro-carbon pads; Frozenrotor rear slotted rotors; SS brake lines, Axxis Ultimate pads; Rota Torque 17x8 wheels; 245/40-17 Bridgestone RE01-R's; Koni inserts with Ground Control coilovers, Eibach springs; K-Mac camber/caster adjustable strut mounts; Urethane swaybar bushings; Bontrager rear sway bar; Urethane differential bushing; Custom Whiteline adjustable rear lateral links; Outlaw Engineering forged underdrive pulley; custom grind Web intake and exhaust cams (11 mm lift, 250° duration); solid lifters; CP custom aluminum forged 11 to 1 pistons, Brian Crower coated SS intake & exhaust valves; Brian Crower upgraded springs w/ titanium retainers; NGK sparkplugs; RallyBob (Bob Legere) ported and polished cylinder heads; Eagle H-beam rods; ACL Bearings; Cometic Head gaskets; ARP head studs & fasteners; Hydra Nemesis EMS; Wideband O2 sensor; 740cc Injectors; Walbro 255lph fuel pump; Upgraded WRX starter; Equal length SS headers (3 into 1); dual Magnaflow cat converters; 2 into 1 into 2 SS exhaust with Bullet muffler; OT Fiberglass hood; Oil pressure gauge; Programmable shift light, 2017 Subaru Forester XT, metallic dark gray, 29,xxx 2005 Porsche 911 Turbo S Cabrio, 24,xxx 2006 Subaru Outback LL Bean, 166,xxx sold 92 LSL Dark Teal, Smallcar Shift Kit - sold Last edited by shotgunslade; 11-21-2012 at 12:48 PM. |
Re: Poll: Should I get a stripe and what color?
Could be interesting... Not generally a fan of graphics myself but in the spirit of Because Rececar I'd vote option 3 in gold.
What about an offset stripe?
No stripe unless you're racing it, adds 15-25 more HP.
Definitely offset. Pics of your car?
Get it wrapped!!
1992 LSL ebony pearl 170k - Thank you Ron Mummert Reading Box of Wine Car ----------------------------------- 1992 SVX LSL 5-Speed Sold at 180K 2019 1995 SVX Lsi Polo Sold at 118K 2007 |
Personally I think stripes are hideous but since you're asking you'll probably get them anyway, even tough survey says no
1994 subaru svx le 112k |
This is something to consider, get it done in vinyl. If you don't like/get sick of it removal is as simple as peeling it off.
Back in the day, before the Young Tom engine transformation and before the paint job deteriorated so badly. Poll, wife and daughter all say no stripes.
____________________________________________ 95 LS-i Red, 31,xxx; bone stock for now; Daily Driver 94 LS-i Emerald Pearl, 106,xxx,; 246 whp; Tomyx snorkus and HKS Cold air intake; PWR aluminum radiator, silicone hoses; Inline thermostat; enhanced coolant routing; external power steering and oil coolers; Phenolic intake manifold spacers; 2004 WRX 5 speed transmission; ACT Clutch Kit, Heavy Duty Pressure Plate, Lightweight flywheel, performance disc; Group N motor mounts; ‘07 WRX 4-pot front calipers, cryo-treated slotted Tribeca rotors; Hawk HPS ferro-carbon pads; Frozenrotor rear slotted rotors; SS brake lines, Axxis Ultimate pads; Rota Torque 17x8 wheels; 245/40-17 Bridgestone RE01-R's; Koni inserts with Ground Control coilovers, Eibach springs; K-Mac camber/caster adjustable strut mounts; Urethane swaybar bushings; Bontrager rear sway bar; Urethane differential bushing; Custom Whiteline adjustable rear lateral links; Outlaw Engineering forged underdrive pulley; custom grind Web intake and exhaust cams (11 mm lift, 250° duration); solid lifters; CP custom aluminum forged 11 to 1 pistons, Brian Crower coated SS intake & exhaust valves; Brian Crower upgraded springs w/ titanium retainers; NGK sparkplugs; RallyBob (Bob Legere) ported and polished cylinder heads; Eagle H-beam rods; ACL Bearings; Cometic Head gaskets; ARP head studs & fasteners; Hydra Nemesis EMS; Wideband O2 sensor; 740cc Injectors; Walbro 255lph fuel pump; Upgraded WRX starter; Equal length SS headers (3 into 1); dual Magnaflow cat converters; 2 into 1 into 2 SS exhaust with Bullet muffler; OT Fiberglass hood; Oil pressure gauge; Programmable shift light, 2017 Subaru Forester XT, metallic dark gray, 29,xxx 2005 Porsche 911 Turbo S Cabrio, 24,xxx 2006 Subaru Outback LL Bean, 166,xxx sold 92 LSL Dark Teal, Smallcar Shift Kit - sold |
Solid color is the way to go.
Good seeing you on here again. How's the svx running?
Tim 92 Liquid Silver SVX 5MT 2009 BMW Z4 (Gone) 2012 Camry V6 SE |
Running really well. YT came back a month or so ago and adjusted the tuning. Had a lot of driveability issues. Now it is really good. The sound and feel of running up through the gears, full throittle, shifting at 6500 is so sweet. The solid top mounts can be pretty harsh on a poor road surface, but the handling, with the new front and rear control arms is very crisp.
Try it out in Plasti-dip. You can paint whatever you want, leave it for a while and peel it off when you get sick of it. Pretty cheap too at $6 a can....
Jon 1997 SVX LSi Bordeaux Pearl 1995 SVX L AWD Polo Green - 277k miles 1986 Pontiac Fiero 3.4L Twin Dual Cam V6 |
Done graphics looong time ago. Now each time I look back I feel stupid (removed them of course).
Stripes are generally good on a wide body/large rims car.. But I wouldnt consider them at all.
The Alcyone Horns are nice. I'd be more embarrased about the wing.
Take pics of the car, transfer to your computer. Put stripes on the car via Paint application in Windows. Evaluate. Decide. Works great for pasting photos of wheels to see what they look like on your vehicle. which I have been doing the the last week. Or I suppose, better, Photoshop.
1994 SVX L FWD "The Blue Bullet" |
I am currently working on a special project that involves it. I will definitely lower it though, probably by 2-3 inches.
