Anybody owns a VW Eurovan?
Just doing some exploratory research on an Eurovan and wanted to know if any of you have any feedback. I'm comfortable with owning high maint cars, especially European vehicles. Still, the English cars have to be the worst car I've ever owned, LOL!
In any case, it seems like the Auto trans are the failure points in these vehicles and with the exception of the 1993 model, they all have automatics. I test drove a '93 with a 5sp and a 5cyl engine and loved it. For our needs, the Weekender version will do nicely with the poptop. We have a very nice 1997 Landcruiser that I'm thinking of getting rid of in favor of picking up the Eurovan. On our road trips, the extra room will be very nice indeed. Anyway, thanks for any feedback.
If it ain't broken it, doesn't have enough features!!! '92 SVX LSL '03 4Runner '96 FZJ80 Landcruiser '90 Mercedes 300E |
Re: Anybody owns a VW Eurovan?
I don't own one, but I know them fairly well. They use the same drivetrain as the year equivalent jettas. The transmissions are awful. Also on the VR6 models, watch for timing chain guide failures. Listen for noise from the timing chain case when the car starts. The timing chain is on the backside of the engine, between the engine and transmission. That's a very costly and labor intensive repair.
2009 Volvo C70 T5 2008 Volvo S80 V8 2006 Range Rover Sport 2001 Audi S8 |
Thanks for the heads up.
Personally, I'd stay away. They fail thanks to the plastic tensioner pads and need to be done about every 100k miles regardless of how well they have been maintained. This one had around 110k miles iirc with excellent maintenance history and one owner. It's about 11 hours of labor if you catch it before it does any damage. Also, while in there, there are a few other parts you want to replace which makes it all quite costly for something that needs to be done at that interval. Last edited by 1986nate; 01-16-2013 at 08:56 AM. |
Bad VAG.......BAD!!!
Tony 1996 Polo Green Subaru SVX LSi, 168,XXX miles, Redline D4 ATF, Redline 75W90 gear oil, K&N HP-4001 Oil Filter, Mobil 1 5W50 FS (3qt) and 5W30 High Mileage (4qt) Oil Blend, Motul RBF600 Brake Fluid, AC Delco A975C Air Filter, NGK BKR6EIX-11 plugs, Centric Rotors, Power Stop Evolution Carbon Fiber Ceramic Brake Pads 2005 Gray Acura RL, 165,XXX miles, Redline D4 ATF with Lubegard Platinum Protectant, Mobil 1 5W20 High Mileage Extended Performance Oil 2009 Red Toyota Venza, 123,XXX, Mobil 1 5W30 High Mileage Oil 1992 Red Ferrari 348 ts, 82,XXX, Redline everything |
I would never buy a VW, or any German car unless I could afford to buy a new one.
1992 LSL ebony pearl 170k - Thank you Ron Mummert Reading Box of Wine Car ----------------------------------- 1992 SVX LSL 5-Speed Sold at 180K 2019 1995 SVX Lsi Polo Sold at 118K 2007 |
In all fairness, I just parked my daughter's 2002 4 cyl. Jetta 5 speed after 190k miles and 4 years, 90K of good hard service under her watch. Still runs great so will probably donate it. It served her, and me, well. My only complaint is the interior and plastics parts self destructed.
Gene
Gene and Ben 1992 SVX LS AWD 110K - Liquid Silver 1994 SVX LSi AWD 128K - White Pearl (daily driver) 1994 SVX LSi AWD 95K - Emerald Pearl (sold) 1992 SVX LS-L AWD 115K - Dark Teal 4.44 swap (sold) |
the 4 cyl engines from VW/Audi are generally good. The exception is when people follow the maintenance schedule for oil changes which is too long on the 1.8t(transverse or longitudinal). The Audi 2.8, 30v V6 is also a great engine and other than having it's oil leaks be fairly typical, is bulletproof. The Audi V8's are generally great as well, though do have transmission/torque converter issues thanks to the higher torque and power. The 2.7 twin turbo, W8, VR6 have a fair share of issues typical around 100k and sometimes sooner and I would never recommend anyone buy them without a decent amount of mechanical ability. Even then, they're not really worth dealing with the headaches and why I chose to stop thinking about upgrading to an Allroad 2.7t from the A4 that I have now. (The V8 allroad was never offered with the 6 spd manual, though I do have all the parts needed to swap one if I chose, but just not worth the investment/bother) They can be great cars if you know what to look out for and if they haven't been driven to the ground. Also, parts are cheaper for my A4 than parts we buy for the Subarus on the lot. (brakes, timing belt parts, sensors, etc) So don't let the myth of expensive parts fool you. Last edited by 1986nate; 01-16-2013 at 06:33 PM. |
Driving the 300E is way more pleasurable than the SVX to me. Again, I said to "me" The fit and finish and the attention to details on this car is rather amazing. This was a hand made car and the quality has since suffered starting in the late '90s. This is the only MBZ I've owned so I can't speak for any other models/years. From what I've been reading, VW's are not known for their fit and finish. As long as the timing belt and associated components are taken care, the 2.8 VR6 ain't a bad engine. The transmission on the other hand is a complete POS. But, the nice thing is that it takes less than hour to complete remove the front of the vehicle in order to access the engine and tranny If I can find an '02 or '03 for cheap, I'll pick it up and then convert it to a weekender. This vehicle would serve my family well for long distant trips I think. Thanks for the inputs.
Sounds like a job for plastidip.
Gene
I have seen some things like what you mentioned as well - tabs holding switches breaking, the plastic tube the dipstick goes in breaking, etc. Seems like the plastic stuff in general doesn't hold up well.
