EGR Port - What exactly is this?
I was looking through svx_commuter's locker for directions on how to test the ohms on the TPS, and I came across this picture labeled "EGR Cleaning Port":
I'd message him myself but his last activity was in 2009. Does anyone have an explanation as to what this does? Do I stick something in here and clear the EGR out with it? That would be fantastic!
1992 Pearl White LS Owned since 2009 175k Miles STi Airlift Performance air suspension 2005 WRX manual swap Rear wheel drive K-Staff front bumper Delta Speed side skirts JDM clear corners Smallcar grille Subaru XT steering wheel Subaru XT shift knob First bagged SVX in the world Worlds first SVX on air suspension. Custom made (by myself) spare tire subwoofer. |
Re: EGR Port - What exactly is this?
I believe the egr valve lets in exhaust to mix in with the air intake for combustion. I believe it's to help reduce pollution.
If I remember correctly, you remove the cover to expose the bolts and remove it to clean. I did this when I removed the intake manifold to replace the vacuum lines. It was dirty with carbon, I used a small pick to scrap the inside to loosen it. I am sure someone else can chime in with more information.
Father of 5 sons and 1 daughter Subaru SVX for fun Hyundai Veracruz for the wife. Susuki SX4 for my older son Ford Ranger for work Mercedes Benz Sprinter for vacation trips, EZ GO Golf cart for driving kids around gated community. Last edited by dannmarr; 04-22-2013 at 10:35 PM. |
I hope so. I've been doing research for the last year trying to figure out an easy way to clean out the EGR without removing a ton of stuff... Also does anyone have a how-to on how to remove the EGR the hard way?
Would like to know also what that is for...
When I was in school I sucked in sports. Then I found out I can buy trophies and now I am great at everything. |
Do a search on intake manifold. There might be a write up about the EGR valve.
Father of 5 sons and 1 daughter Subaru SVX for fun Hyundai Veracruz for the wife. Susuki SX4 for my older son Ford Ranger for work Mercedes Benz Sprinter for vacation trips, EZ GO Golf cart for driving kids around gated community. Last edited by dannmarr; 04-22-2013 at 10:34 PM. |
Exhaust Gas Recirculation valve.
Its both an emissions device and had impact on volumetric efficiency under certain conditions. Main function is to recirculate a small percentage of exhaust gas back into the combustion chambers at the "correct" engine load to reduce NOx (nitrogen oxide) gases. When working correctly (can be finicky on the SVX) it will not rob any power from the engine. When not working efficiently, it can have negative effects on fuel economy and power just to name a few. The higher combustion chamber temperatures actually help to break down and displace NOx formulations commonly considered a harmful pollution especially in urban cities. Its only actually actuated in the mid-band area of the power curve, never at idle or full throttle. There is much more to the science behind this, but I just deal with non-working EGR valves, compliance, and basic reasons behind function. Hope this helps a bit.
-- Chris Founder/Administrator SVX World Network ECU Tune (stage 1), PWR (prototype aluminum radiator) Amateur Radio - General Class - K7SVX #1 92 Teal LSl 246k (Dedicated SVX Race Car, now with 4.44 speed) #2 92 Teal LSl 125k (Retired, car rescued from a field of weeds) 2007 Impreza 2.5i Special Edition, Obsidian Black Pearl (Daily driver) 2001 Dodge Ram 2500 quad cab, Cummins turbo diesel 4x4 (race car & RV hauler) 1985 Honda VF500 Interceptor (fair weather fun commuter) Going on 11 years of NHRA bracket racing NHRA Div 6 Car/Driver # T654 (site being rebuilt, new name is www.teamsvxracing.com) 2000 1st Place Club Challenge Series 2002 3rd Place Season Track Champion, Import Racing (Firebird Raceway) 2003 4th Place Season Track Champion, Import Racing (Firebird Raceway) 2003 1st Place NW Regional Import Shootout (July 5th) 2004 1st Place Club Challenge #1 (Firebird Raceway) 2004 1st Place NHRA "King of the Track" race 2004 NHRA Gold Cup 2nd place season win 2004 Import/Sport Compact 3rd place season win 2004 Division 6 Summit/ET NHRA Race of Champions finalist competitor (Mission, BC) 2007 1st Place Import Survival #3 2007 1st Place Track Champion Import Summer Jam (Wild Street Class) 2007 1st Place Import Survival #5 2008 Club season 1st place win, Club Champion 2008 2nd Place Season Import Final. 2008 Division 6 Summit/ET NHRA Import Finals (Woodburn, Or) 2009 2nd Place Import Summer Jam (Wild Street Class) 2010 1st Place Club race #2 - 1st place Sport Compact race #1 & #2 |
It does! Interesting how much one part can effect the whole car. But what exactly does that port do? Can one dump a cleaner in there and wash it out (seafoam)? Does one stick a pipe cleaner in it?
I live somewhere without emissions so i removed the pipe and stuck a bolt in both spots to block it off.
1992 SVX Pearlie: AmsOil signature synthetic 10w40 and Ea15k20 filter, Cobb crank pulley, Outlaw Engineering spacers and tb bypass, LGT 5spd, Slotted Crossdrilled rotors and ceramic pads, 11:1 compression, EGR delete, Port & Polished heads, SaikoMichi catch can, A/c delete. |
The bolt in the picture I believe is a plug. Non California or pre 96 models use this plug in place of an EGR sensor.
"The things you own end up owning you. It's only after you lose everything that you're free to do anything." 92 Pearl White Ls-l (138k) Euro Headlights & Blinkers, 97 Grill, Euro Tail Lights, SS Brake Lines, Stebro Exhaust, Slotted Rotors, Classic Registration 96 Legacy Outback (206k) 5-speed 2.2 Lightweight Crank Pulley, Group N Trans & Motor Mounts SOLD Wanted: Steering Wheel |
Maybe these pictures can be of some help.
The bolt in the picture is not what the EGR actually plugs into. The EGR is a smaller pipe with a flange and 2 philips head screws holding it in place that are just about guaranteed to be stripped when you try to remove them. It is directly behind the top bolt that the picture points to. I wasn't aware that you could clean the inside by removing that bolt - but it would be interesting to take it out and see. Inside the tube will be a caked up mess.
Matt Locker Link 2015 BRZ Limited 6MT 92 Ebony LS-L ECUtune Stage2av1, Z32 MAF, 370cc injectors, TomsSVX intake, BontragerWorks 22mm RSB #003, HID Hi and Lo beams, OT endlink and bushing mods, PWR Aluminum radiator, Harvey's QC shift kit, 2.5" flowmaster 80 exhaust, 17" Michelin Pilot Sport A/S, Poly sway bar bushings, Slotted Bradi rotors, AFBeefcake powdercoated calipers, 97 grill, and a huge set of air horns. 300,000 miles and counting 92 Ebony LS-L. ecutune stage1v4, motorsport 1pc pulley. Garage Queen - sold to Dad in upstate NY 155,000 miles 19 Subaru Ascent Premium - -Hers !. 89 DL 4x4 little red wagon - a.k.a. The immortal suby. 275k R.I.P. Last edited by immortal_suby; 04-23-2013 at 02:48 PM. |
