Is there a 5 speed 4.44 transmission?
Hello all,
Lately I've been wondering about switching over to a 5 speed. The question is does a 5 speed exist with 4.44 gears? I already own a 4.44 automatic transmission and rear diff so that way all I would have to swap would be the transmission, correct? Thanks all for your input, Sam. L Svx95
Sam Brilliant Red 95 SVX L AWD 149K miles - #904/1801, 08 STI 6MT with DCCD & VSS, ACT SB10 HDSS, 6MT bushings, DW200 Fuel pump, 17x7.5 VX-SCYTHE Wheels, 17x8 BBS STI Wheels,PERRIN CRANK PULLEY, 911 Turbo oil filter,$15/15min MOD & $20/20min Mod, Brontrager WORKS 22mm RSB w/ QS component endlinks, SS Brake Lines, DDM TUNING 6000K HID LOWS, Hella Optilux Extreme Yellow Fog Lights,Window scratcher fix, JDM Clear Corners My Locker |
Re: Is there a 5 speed 4.44 transmission?
Yeah, but they are pretty rare. IIRC, they are found in some Fox and Baja turbos?? And a few more JDM models.
Forester and Outback XT models used a 4.44 5MT
Overseas, (JDM, Europe, Australia) Impreza STI Version 3 or 4? also used a 4.44, as well as the Legacy GTB. All are turbo transmissions with hydraulic pull clutches. I have the JDM Legacy GTB 4.44 in my WRX, (last three digits of the tranny code are CAA if I recall correctly). While it's a great upgrade for the torque-less turbocharged 2.0 in my Impreza, I feel it may not be well suited to the broad power band and low end power of the 3.3. Unless you like spinning four tires and accelerating like a bat out of hell. 70mph in my Impreza is buzzing along at 3500 rpm. Gets there just fine, though. From Nasioc.com: Factory Gear Ratios for Reference All-Wheel-Drive 5-speed Transmissions USDM 3.454 / 1.947 / 1.366 / 0.972 / 0.738 / 3.900FD - '02-'05 USDM WRX; 3.545FD rear diff 3.454 / 1.947 / 1.366 / 0.972 / 0.738 / 3.700FD - '06-'07 USDM WRX 3.166 / 1.882 / 1.296 / 0.972 / 0.738 / 3.900FD - '08-current USDM WRX 3.454 / 1.947 / 1.366 / 0.972 / 0.738 / 4.444FD - '04-'08 Forester 2.5XT 3.454 / 2.062 / 1.448 / 1.088 / 0.780 / 4.111FD - '04-current Forester non-turbo 3.166 / 1.882 / 1.296 / 0.972 / 0.738 / 4.111FD - '05-'06 USDM Legacy 2.5GT 3.166 / 1.882 / 1.296 / 0.972 / 0.738 / 3.900FD - '07-'09 USDM Legacy 2.5GT 3.166 / 1.882 / 1.296 / 0.972 / 0.738 / 4.444FD - '05-'09 USDM Outback 2.5XT 3.545 / 2.111 / 1.448 / 1.088 / 0.780 / 4.111FD - '98-'01 USDM Impreza 2.5RS 3.545 / 2.111 / 1.448 / 1.088 / 0.780 / 3.900FD - '96-'01 USDM Impreza L/OBS 3.545 / 2.111 / 1.448 / 1.088 / 0.780 / 4.111FD - '96-'99 USDM Legacy 2.5GT 3.545 / 2.111 / 1.448 / 1.088 / 0.871 / 4.111FD - '96-'99 USDM Legacy Outback 3.454 / 2.062 / 1.448 / 1.088 / 0.871 / 4.111FD - '00-'07 USDM Outback 3.454 / 2.062 / 1.448 / 1.088 / 0.825 / 4.111FD - '08-current USDM Outback 3.454 / 2.062 / 1.448 / 1.088 / 0.780 / 4.111FD - '02-'04 USDM Impreza 2.5RS/'05 Impreza 2.5RS Sport 3.545 / 1.947 / 1.366 / 0.972 / 0.780 / 4.111FD - '93-'94 USDM Impreza 1.8L 3.545 / 2.111 / 1.448 / 1.088 / 0.825 / 3.900FD - '95 USDM Impreza 1.8L JDM 3.454 / 2.062 / 1.448 / 1.088 / 0.825 / 4.111FD - '93-'96 JDM Impreza WRX/STi 3.454 / 2.333 / 1.750 / 1.354 / 0.972 / 3.900FD - '93 JDM Impreza WRX RA 3.454 / 2.333 / 1.750 / 1.354 / 0.972 / 4.111FD - '94-'95 JDM Impreza WRX RA/STi RA 3.454 / 2.062 / 1.448 / 1.088 / 0.825 / 4.111FD - '93-'00 JDM Impreza WRX Wagon 3.083 / 2.062 / 1.545 / 1.151 / 0.825 / 4.444FD - '97-'00 JDM Impreza WRX RA/Type R/STi RA/22B STi 3.166 / 1.882 / 1.296 / 0.972 / 0.738 / 4.444FD - '97-'00 JDM Impreza WRX/STi
1994 SVX- 5MT, Deltaspeed, Stebro,Work VSXX 1994 Legacy GT 2001 Forester 2002 Impreza WRX 2005 Impreza WRX STI Need parts? Last edited by Subachouli; 09-19-2013 at 05:09 PM. |
That is an interesting note! As I said, I currently have the 4.44 automatic from a 90's legacy I believe and my rpm at 70mph is at the most 3250 rpm and it does accelerate pretty quick. Would you say that the 5mt is weaker than the automatic then? Everything I've read about the MT is that they are stronger! The whole purpose of the swap is because further down the road 4+ years I would like to turbo the SVX.
So would this work for a 1995 Svx that already has an automatic 4.44 conversion? --> http://www.ebay.com/itm/99-05-Subaru...7df979&vxp=mtr
Out of these two JDM 5 spd transmissions which would be the best to go with for the 4.44 conversion? Also would I still use the outback/legacy driveshaft?
