Dynomat or similar
Anyone used any types of insulation to lower road noise? After installing all-metal coilovers, road noise has become a bit obnoxious. I think using dynomat would be best, but it's way too expensive. A lot of people say they use that peel n stick stuff from Lowes or Home Depot because it's affordable. Anyone here used anything similar? I also don't want anything that produces a fowl odor...
1992 Pearl White LS Owned since 2009 175k Miles STi Airlift Performance air suspension 2005 WRX manual swap Rear wheel drive K-Staff front bumper Delta Speed side skirts JDM clear corners Smallcar grille Subaru XT steering wheel Subaru XT shift knob First bagged SVX in the world Worlds first SVX on air suspension. Custom made (by myself) spare tire subwoofer. |
Re: Dynomat or similar
B-Quiet from Canada is cheaper and reports like it as well as Dynamat
I used a ton of these products.... they performed very well in a comparison test (Dynamat + others).
http://stp-distribution.com/ (made in Russia (!) and may not be available in the US). So far I've done only backwards from under the rear seat (20 kg of material), but with very good result. Tire noise was reduced significantly. I also used the SPL polyurethane foam (10mm) behind all trim panels. No rattles. Tapani |
I've used B-quiet a couple of times and it works well and is cheaper
The stuff from Home Depot was discussed at length on the CR-Z forum when I was an owner. DON'T USE IT! On a hot day your car will smell like a roof getting re-tarred and the stuff will start to peel off. It wasn't meant to be put in cars.
1996 SVX LSi : Work in progress, future garage queen 2013 Acura TSX: Mistake |
