Go Back   The Subaru SVX World Network > SVX Main Forums > Competition Motorsports
Old 06-05-2014, 10:18 PM
SVXBart SVXBart is offline
AX breaks set up.
My car needs break job so i decided to replace most of the system components.
will be getting new rear calipers,SS lines ,valvoline syntec fluid,new pads and rotors front and back.
Car is driven on weekends an for AX.
I need some advise from active Autocroserss on their pads and rotors choice.What r u running and and how it works so far.I dont wanna break the bank but i wanna be able to stop fast to.And i dont wanna change my rotors every 2k miles.
A set from frozen rotors +hawk pads is about 650$,similar set from StopTech is about 500$.I can get a set from Motorsportsvx for 380$.
What is ur opinion?
Thanks in advance.
Bart
Bart
Old 06-07-2014, 06:33 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Re: AX breaks set up.
the SS lines will give you the biggest bang for your buck. Slotted and cryo'ed rotors will last you forever. Tire patch is what actually stops you. You will probably not be cycling the car enough to have brake fade, so a good semi-metallic pad will be fine.
Retired NASA Rocket Scientist
Center Network Member #989
Old 06-09-2014, 11:45 AM
LetItSnow's Avatar
Still Cant' Say the Z-Word
Check your lead time; not everything is in stock, and not all e-mails receive replies.
Old 06-09-2014, 08:58 PM
Thanks Bill .I was hoping u would reply.What setup r u running on ur pearlie?
I need to take care of my breaks right away due to bad caliper.A new set off wheels and tires is next on the list.
Bart.
Bart
Old 06-10-2014, 01:12 PM
SVXRide's Avatar
Bart.
Bart,
I'm upgrading what Harry was running. Just got slotted and cryo'ed rotors for all four corners and I have rebuilt/powdercoated calipers for all four corners. I'll be running EBC pads, as there will be some track time in the Mach 5's future in additional to the mandatory autocrossing.
Bill
Old 06-10-2014, 06:21 PM
Thanks Bill.
I dont wanna be a copy cat,but thats what i had in mind doing too.
Same set up.
Time to order some stuff then.
Bart.
Bart
Old 06-19-2014, 11:55 PM
Gamesy's Avatar
Gamesy Gamesy is offline
where do you get SS lines for the svx? do they use the same ones as the impreza?
Old 06-20-2014, 03:46 PM
i got my from Svxfiles but i think he gets them from Dyle at Motorsportsvx
Bart
Old 06-20-2014, 06:59 PM
Yes, ^ what He said.
Old 06-23-2014, 08:42 AM
newsvx's Avatar
newsvx newsvx is offline
Send a message via Yahoo to newsvx
What SVRRIDE said, Bart ..... I never had a broplem stopping the Pearlie with semi-metalic pads and slotted rotors. Actually never had much trouble with warped rotors either. And ask Bill .... I "worked" the brakes!
Good luck on the brake job .
Harry
newsvx
1992 SVX LSL, #1215
1997 SVX LSi, #370
"I live with fear every day. Sometimes she lets me go racing."
"Getting Older and Slower"
Locker: http://www.subaru-svx.net/photos/user.php?newsvx
