Looks like a headgasket issue...
...on the Tribeca.
Wife came home and the car was "making a funny noise". I came out and heard a hissing noise. That's not good. Saw a liquid pooling under the car. That's not good. I thought I smelled coolant. Ugh. Then I dipped my finger in the liquid and it was oily. WTF? Popped the hood. Overflow tank looked normal for level. Checked the dipstick. Definitely lost a little oil. Level was halfway between L and H. Looked under the car and it looked like the leak was coming from near the oil filter. Popped off the cover and looked up there with my scope. The oil filter and sandwich style oil cooler looked clean. I couldn't see where the leak was. Temp gauge had definitely gone above midway but CEL was off. Checked the coolant in the overflow tank and it looks like watered down Cola. I am assuming the headgasket. But why didn't the overflow tank overflow? And why did I get the hissing from under the engine? Could the oil cooler have sprung a leak? Could something worse than a headgasket have failed? I heard no other unusual noises when the engine was running nor did I see anything on the dipstick other than honey colored oil.
Tony 1996 Polo Green Subaru SVX LSi, 168,XXX miles, Redline D4 ATF, Redline 75W90 gear oil, K&N HP-4001 Oil Filter, Mobil 1 5W50 FS (3qt) and 5W30 High Mileage (4qt) Oil Blend, Motul RBF600 Brake Fluid, AC Delco A975C Air Filter, NGK BKR6EIX-11 plugs, Centric Rotors, Power Stop Evolution Carbon Fiber Ceramic Brake Pads 2005 Gray Acura RL, 165,XXX miles, Redline D4 ATF with Lubegard Platinum Protectant, Mobil 1 5W20 High Mileage Extended Performance Oil 2009 Red Toyota Venza, 123,XXX, Mobil 1 5W30 High Mileage Oil 1992 Red Ferrari 348 ts, 82,XXX, Redline everything |
Re: Looks like a headgasket issue...
hopefully your dark coolant and the leak are unrelated. i have seen the small hoses that go to the oil coolers leak, sometimes only when under pressure. it creates a clean spot because the coolant cleans gunk off your engine and makes it oily. it would be unusual to have an internal and external head gasket leak if you had no previous signs of trouble. overflow reservoirs don't need to overflow if the coolant has another place to go, or you are not that hot.
you can test for a head gasket internal leak with this for $30 or less. an external leak you will just have to run it and watch for leaks. how does the fluid in the radiator look?
Current Stable: 1992 SVX 1979 K5 Blazer Cheyenne 1956 Plymouth Belvedere - Daisy 1967 Chevy C20 1953 Chevy 210 1969 Plymouth Satellite 1949 Chevy Thriftmaster 1959 Chevy Apache 1951 Chevy Stepside 1969 Chevy Camper Special 1978 Ford F150 w/ stroked 460 1986 Volvo 740 turbo wagon 1999 GMC 2500 Creep Van 1994 Impreza Outback |
I didn't extract coolant from the radiator but i did wipe the inside of the neck and it was slippery.
coolant usually feels slippery. oil and water don't mix well so oil will usually be separated from the coolant to some degree. once it gets mixed it looks like a chocolate milkshake.
What do you have coming out the exhaust...any white smoke or sweet smell of coolant? I've found putting the overflow hose in a container of water will show bubbles with an internal leak since you can leave the cap on and system
Didn't check the exhaust but I don't recall anything unusual. It is at my mechanic's place now.
It turned out that it was only a burst hose. The slippery feel was not oil after all. Sometimes we get lucky. The money ended up going toward a new clutch for the Acura.
