Old 11-29-2002, 10:58 AM
Uncamitzi's Avatar
Member #447
Question Small Shake at Idle
If someone has any idea what's happening here I would really like their opinion.
The car feels fine. When I pull up at a stop light and the engine slow's to idle, I get a small shake kind of like a engine miss, but I'm pretty sure the engine is running well. Here's the rub (so to speak) If I shift it into neutral the shake goes away. The idle speed changes only slightly maybe 50rpm or so. When I drop it back into Drive with my foot on the brake, the shake has, for the most part gone away. It builds back slowly as I sit with the car in gear and my foot on the brake. In neutral it hardly feels like the car is running. But with the car in drive I get the vibration. I haven't heard anyone talk about this before so I'm worried about the transmission.. ( I always worry about the transmission ) Any help ?
Thanks
Mitch Hansen
"uncamitzi"
This is a Dark Ride
Old 11-29-2002, 12:04 PM
Green1995SVX
Mine does the EXACT same thing. Todd (wawazat??) even commented on it when we went for a "beer run" in my car a few weeks ago. I dont let it concern me, but it would be fantastic if we could figure out how to fix it.
Mike
Old 11-29-2002, 02:52 PM
nickhawaii
Smile
Glad to hear my car is not the only one with a little vibration -- only at low idle too. If the AC is on -- no vibration. My tech is convinced the motor mount bushings need to be replaced. Will let you know how it turns out.
aloha
nick
Old 11-29-2002, 04:59 PM
Beav's Avatar
Beav Beav is offline
Not as old as Randy
Probably a small vacuum leak. I found one in mine some time ago. There's a vacuum reservoir under the right side of the intake manifold. In front of it (towards the p/s pump) is a vacuum hose with a small check valve. My check valve had cracked from years of heat and was just enough of a leak to put a small 'bump' in the idle. See: 'Vc tank' at http://www.subaru-svx.net/photos/files/Beav/5309.gif
Others have found loose intake plenums and manifolds, etc. Vacuum leaks are the most common cause of idle roughness (with no other symptoms.)
Old 11-30-2002, 12:03 AM
Uncamitzi's Avatar
Member #447
Lightbulb Thanks Beav
Guess where my head will be in the morning!
Mitch Hansen
"uncamitzi"
This is a Dark Ride
Old 12-01-2002, 02:24 AM
mbtoloczko's Avatar
sans SVX
Mike
Mine does this too. I just noticed it last week.
Mychailo
Visit my locker
Old 12-01-2002, 09:13 AM
wawazat??'s Avatar
Yeah, I'm still around
Mike
mmmmmmm-beer! Good! Shakes, bad.
Todd
Down to none
Old 12-01-2002, 12:02 PM
Mr. Pockets's Avatar
Moderator
I've found that some gas makes my car shake a little at idle. When I lived in VT, there was a 'discount' gas station that I always bought my gas at. I tried switching to a Sunoco station or something like that, and the shake went away.
2005 RX-8 Grand Touring
2005 Outback
2002 Mercedes-Benz E320 wagon
END OF LINE
Old 12-02-2002, 08:31 AM
immortal_suby's Avatar
Thread Killah
When I removed the intake I found that alot of those small rubber vacuum hoses were so brittle they just fell apart. Probably leaked quite a bit up until that point.
Locker Link
2015 BRZ Limited 6MT
Old 12-02-2002, 10:05 AM
Uncamitzi's Avatar
Member #447
Question ?
When you say you removed the intake (I haven't had a chance to check the hoses yet), what exactly did you take off? The Intake manifold? If so I may need more than a weekend to get to the hoses.......
Mitch Hansen
"uncamitzi"
This is a Dark Ride
Old 12-02-2002, 10:25 AM
Thread Killah
Just the top intake part. Pictures are in my locker. It is not hard to do at all, just plan on having enough extra hose to replace the ones that are cracked and new intake gaskets. If you haven't changed the PCV valve yet, this is a good time to do it.
Locker Link
