AFT in Differential???
I began doing some general maintenance on my recently purchased 97 LSI.
Changed all the fluids this weekend and found a red/brown watery fluid (looked like burnt ATF) come running out of the front differential when the drain plug was removed. This is nothing like the gear oil specified on the manual either in consistancy or color. I replaced it with the gear oil specified. Has anyone else seen or heard of this? Could this have casued any damage? The car does run fine. Thanks! |
Re: AFT in Differential???
Although the trans fluid was dirty, it did not appear to have any gear oil in it, thank God!!
With your bearing / seal failure, did you get ATF into the differential also? |
I'v heard of the tranny fluid getting in to front diff, I think It's the more common problem. I however experieced the disapering gear oil problem myself. There are two seals that can go bad, the pump seal, that the main shaft runs through that goes to the converter is the one that leaks ATF in to the diff. The pinion seal that the pinion shaft runs trough and is lower down, is the one that lets the gear oil in to the tranny. If I where you I'd get it fixed, or run it till it blows up and get a 5speed
92 SVX #772 140k 6speed, ECU Tune stage II, Koni/Ground control, 3,270lbs. 91 Legacy Turbo 5spd. FMIC, crappy stock turbo, ACT clutch. 78 BRAT (New toy) (Soon to be EJ22T powered) 90 240 SX. RB25 powered!! DRIFT!!!111!!! (GF's car) To many cars to spend time on teh web! |
I'm hoping that some Jiffy Lube place just put in the wrong thing, and that not too much damage was done!!
I'll have to keep an eye on it and see if the trans fluid again winds up in the differential. Does the fix for these seals in question require removal and disassembly of the tranny, or just pulling the diff? |
Re: Re: AFT in Differential???
When you install a 5-Speed Then it'll just be a new clutch now and then....much cheaper than an auto rebuild
Re: Re: Re: AFT in Differential???
The confusion over fluids, is somewhat understandable, but folks should always double-check WHAT they're putting in WHERE. It's like when I went for a tranny flush, I kindly let the tech know, "I know you probably already know this, but, some people don't. The tranny drain plug is the one on the Driver's side." He just nodded. If you don't act like you're telling them something they already know, then, they're much more apt to accept your instructions. "When I rotate my tires, I never torque my wheel nuts over the factory recommended 65 foot pounds. Do you think that's a good idea?" That's how I let the tech know that I'm anal about my wheel nut torque and give him the correct setting for his wrench.
