Dexron type for PS
Hey all, I just replaced my power steering o ring and I just realized that the subaru manual says to use dexron 2 atf but I used dexron 3. Am I going to damage my PS pump? Should I siphon it out before its too late and replace it back with dexron 2?
Tim 92 Liquid Silver SVX 5MT 2009 BMW Z4 (Gone) 2012 Camry V6 SE Last edited by Tim; 03-22-2003 at 08:03 PM. |
Nah... dextron III is jsut a new improved dextron II. You're all good.
Mike |
PS fluid
Hey Te, Dextron 3 has replaced Dextron 2 and it is backwards compatible. BOBB
Whew, Thanks. I got worried after going through all that work replacing my o-ring. That would have wrecked my day if they werent backwards compatible lol.
Tim 92 Liquid Silver SVX 5MT 2009 BMW Z4 (Gone) 2012 Camry V6 SE |
PS fluid
Subaru actually sells their own ps fluid. Its not that much more that ATF and I was told once that it'll make everything last longer in there (I'm sure its not 100% true but....)... Otherwise Dex 3 is just a newer version of 2 and will do the job fine. I actually think that its formulated for higher temps then 2 (kinda like brake flut DOT #s.
British vehicles are my last ditch attempt to keep the nasty Italian thoughts in my mind at bay. So far its working. |
