"door" lighting fuse location?
In the process of trying to find a ground wire, I accidentally shorted out the circuit that turns on the interior lights when the door is opened, and now I can't find the fuse location. Is that fuse not in the standard locations (kick panel and under the hood)? Or maybe there is a timer circuit I trashed and need to replace? Any help on how to get the interior lights working with the door would be greatly appreciated.
do you mean just door lights or like dash lights for the speedo and such? those lights run on the "clock" fuse
1992 Pearlie ... ??????k Sold 8/04 Kenwood KDC-MPV619 Wedgie Cupholder 1998 Acura Integra LS 74k Sold 1/07 2007 Toyota Tacoma Prerunner SR5 .04k! 2011 Toyota Tacoma Double Cab, 4x4 TRD Sport |
